The Master Of Magnetics "Steven Mark"
Started by Mannix, January 30, 2006, 06:18:53 PM
tao
http://youtube.com/watch?v=XsOxlu98bbU
His output looks an awful lot like SM's powerful arcing seen in his video... lol...
z_p_e
JARO recently made a post on jlnlabs describing the Solfeggio scale based on numbers 3, 6 and 9:
I'm posting this here because I believe that a MIX of certain special
frequencies can vibrate Aether and so produce HIGHER-DIMENSIONAL FIELDS causing
effects like ANTIGRAVITY and TIME-REVERSAL. That'd certainly explain the
powerful effect that John Keely could produce with various sounds. The special
frequencies could be those in the ancient Solfeggio musical scale, which are
said to have been encoded in the Bible.
But when I analyzed those frequencies I've realized that it is most likely
WRONG. 5 of the 6 Solfeggio frequencies have an interval of 111Hz between them,
but not the first one. It doesn't make much sense to have the interval between
two notes in a scale only 21Hz when all the others have a 111Hz one. So I'm
PRETTY SURE that the number 396 DOESN'T belong into this musical scale. The
CORRECT  first frequency should be 306, not 396.
And since it's well known that the Jews stole parts of the Bible from other
races and then claimed them as their own, it's quite likely that during all that
copying and re-writing, they made a mistake and wrote 9 instead of 0, thus
changing 306 into 396.
The Solfeggio scale is here:
396, 417, 528, 639, 741, 852
And the corrected, Jaro's musical scale is:
306, 417, 528, 639, 741, 852
And the reason why I'm quite certain this is correct, is because my musical
scale is mathematically perfect, while the Solfeggio scale is not. I've searched
the Net but haven't found anybody to list the scale with the first number 306
instead of 396.
Oh, and the numbers 3,6,9 are encoded in the scale, as can be seen when you add
up digits of each number (306 is 3+0+6=9, 417 is 4+1+7=3, etc.).
Portals to other dimensions? Sounds good to me. Here's some info about the
http://www.redicecreations.com/specialreports/2006/01jan/solfeggio.html
"The 3, 6, and 9
As we look at the six original Solfeggio frequencies, using the Pythagorean
method, we find the base or root vibrational numbers are 3, 6, & 9. Nicola Tesla
tells us, and I quote: "If you only knew the magnificence of the 3, 6 and 9,
then you would have a key to the universe."
John Keely, an expert in electromagnetic technologies, wrote that the vibrations
of "thirds, sixths, and ninths, were extraordinarily powerful." In fact, he
proved the "vibratory antagonistic thirds was thousands of times more forceful
in separating hydrogen from oxygen in water than heat." In his "Formula of
Aqueous Disintegration" he wrote that, "molecular dissociation or disintegration
of both simple and compound elements, whether gaseous or solid, a stream of
vibratory antagonistic thirds, sixths, or ninths, on their chord mass will
compel progressive subdivisions. In the disintegration of water the instrument
is set on thirds, sixths, and ninths, to get the best effects."
In the book of Genesis it states that there are six days of creation. Yet many
talk about the creation week - or seven days, and the Christian Bible views the
number seven as the number of completeness. Why Seven? It is due to the
influence of the Near Eastern culture at the time in which Jesus lived, when it
was believed that there were only seven planets.
When wrestling with adding a 7th number, I was mystically drawn to an article in
Discover Magazine. In his newest book, Just Six Numbers, Rees argues that six
numbers underlie the fundamental physical properties of the universe, and that
each is the precise value needed to permit life to flourish. In laying out this
premise, he joins a long, intellectually daring line of cosmologists and
astrophysicists (not to mention philosophers, theologians, and logicians)
stretching all the way back to Galileo, who presume to ask: Why are we here? As
Rees puts it, "These six numbers constitute a recipe for the universe." He adds
that if any one of the numbers were different "even to the tiniest degree, there
would be no stars, no complex elements, no life." (From Discovery Magazine). As
some authors have speculated, could these tones have played a role in the
miraculous shattering of Jericho's great wall in six days before falling on the
seventh day? Some scientists are now stating that if we have been created, we
most likely would have been sung into existence. Is it possible that the six
days of creation mentioned in Genesis represent six fundamental frequencies that
underlie the universe? Religious scholars believe both events occurred as a
result of sounds being spoken or played.
Other scientists, including the geniuses Nikola Tesla, Raymond Rife, as well as
Mozart, Haydn, Beethoven, and Chladni, all must have known about, and used the
concept of, the inherent power of threes, sixes, and nines. So we are dealing
with three powerful numbers: 3-6-9. Everyone of the six Solfeggio Tuning Forks
all add up, individually to the Pythagorean scheme of 3-6-9. In fact, because
there are two sets of 3-6-9 (anagrams) in the solfeggio, they are even more
powerful as these combinations serve as "portals" to other dimensions!"
Jaro
Note that the 3 frequencies prescribed by Steven Mark (F1, F2, F3) correspond with the 3, 6, 9, theorem.
Darren
BEP
Re: these 'blobs of silicone'
I am certain this white material is Rob Roy ceramic encapsulation material. It was used to solidify the position of electrical wiring and components in extreme invironments. You pour it on and it hardens like a piece of fired ceramic. Also used to create space born PC boards and seal explosion proof connections. Nasty stuff.... You use it and it winds up everywhere.
The small toroids appear as center tapped secondaries to power the circuit and provide current directional signal to the control.
I see this fitting SM's patent on his pulse control circuit and comments - something about using space-age/military construction to stabilize circuit performance????
No - they are not heat sinks. I'm sure of it.
Re: Sawteeth
When I look at those I see the effect of tightly wrapping 88 (black electrical tape) around a core that has spaced turns of copper wire around it. Each peak would then be another turn of that control coil. There appear to be four different control coils.
Just my clouds?
Jdo300
Hello All,
Here is some food for thought... Looks like Physicists are just now starting to see what Steven Mark discovered ages ago :).
http://www.spectrum.ieee.org/sep07/5498
God Bless,
Jason O
acerzw
@jdo300
Great find, conventional science playing catchup yet again...
Acerzw
In a Holographic Multiverse everything is smoke and mirrors!
What is Reality? Improve yours: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13459
A shorter version for the very open-minded: http://www.overunity.com/index.php?action=dlattach;topic=3454.0;attach=13866
