mpav
Quote from: hartiberlin on February 07, 2006, 10:52:55 PM
is this the mentioned UEC corporation ?
http://www.uecus.com/aboutus.htm
Does anyone know for sure if this is the UEC company we keep discussing.  If so, are there any Floridian readers close to this place that would be willing to make a visit to this place?
Better yet can Mannix get Marks to verify whether this is the company or not?
PaulLowrance
Quote from: Kosh on September 10, 2006, 06:57:08 PMAnd I doubt a person can measure a 7.3 Hz mechanical vibration just by hand. That is silly!
Steven never said it was measured by hand and actually it would be extremely easy to measure. There are a lot of methods. A simple & cheap method is to use a speaker and a frequency meter or scope.
Paul Lowrance
raburgeson
Back on page 16 an anomolous TV set was being talked about, I posted a piece on one in the old yahoo forum.
Isn't it when you broadcast a minute signal to an antenna and receive a larger signal than you would without the broadcast to be considered gain. If you can project a magnetic pulse into a larger field couldn't you somehow attract some of that larger field to the core of source? If you could I would assume this to be gain. A coil (aircore) sends out a pulse that's said to be infinite. So some is lost. No core present to limit the flux growth. But if we insert a core at the correct time and then colapse the field would it pull additional flux from another field. This core can be inserted using an electromagnet that holds no residual magnetism. I know I am mouthing off before I read all 155 pages, I'm sorry, and at my age I should know better.
Stephen , I can't get the link to energycoil44.jpg too work, can you fix it?
I stop and think of all the work I've done to try to iliminate the kick, we first blamed current source inverters of producing the pulse ( spikes going above 100KV) also open transition to close transition spikes). So forgive me I won't crack a book yet, I am accointed with this kick and marvel it can be put to use. (made it to page 20)
Hi Tao,
this is very important information !
Did you get this information directly from Steven ?
have you been in email contact with him recently ?
What else did he email you ?
Better post this again in the Steven Marks thread also.
Many thanks.
Regards, Stefan.
Hi Tao,
so is this the configuration of the 1 KW Mark?s unit ?
So 3 copper coils ontop each other with some control coils
wound around each copper coil and around all 3 copper coils...
hmm.. so the copper coils work as the output ?
Are the control coils then iron wire coils or also copper coils ?
How does he squeeze the water-juice out of the wire, without using
any energy ?
Is this some kind of Lentz law violation resonance effect ?
Tao,
maybe you can post your ideas in steps so not all
in one posting but your ideas you have now already and
the next ideas then next...
Thanks.
Regards, Stefan.
