0 Members and 24 Guests are viewing this topic.
starcruiser
Quote from: Jdo300 on September 18, 2006, 01:11:11 PM
Now that we have the idea of the rotating magnetic field settled on, we should start discussing how the feedback mechanism works for this device? Once the rotating fields start producing power in the collector coils, how does this resulting power get fed into the coils producing the rotating field?? Could this be what the third control coil that encompasses the three smaller control coils does? What do you all think?
God Bless,
Jason O
I had an ephiny, with the SM design what if those smaller internal coils are the feedback pickups?? maybe one is the tickler and the other is the feedback pickup?
Also, I was thinking that instead of 4 coils we use maybe 3 control coils wrapped toridally around the collector coils instead (three segments)? Then those coils are pulsed sequentially? If the collectors can be tapped we can rectify the output (or use a smaller collector coil) for powering the control electronics? Whaddya think?
Giantkiller, to your last question regarding control/trigger... (was thinking on this
As for the control circuits to KISS (keep it simple...), we use a 555 timer with its output run into a shift register or something similar and use the outputs to trigger some power transistors to handle the coil pulsing?? This would work for either ingnition coils (three of them or four) or directly powering the control coils. I think this is a good starting point what do you think????
This coming weekend I will be building my own TPU coil using the above ideas, 3 control coils and multiple collectors (3 main outs and one control power coil with full wave rectifiers and filter caps to check the outputs. I also like the idea of the capacitor to change the phase angle, but I think that idea would be best for 2 control coils.
I'll post more after I complete the build or if I come up with any other ideas. I'm getting a good feeling here, I think we are on to something.
Carl
Carl
raburgeson
Has anyone rotated the field yet? Steven Mark's said study the toroid.
giantkiller
Finally...
Great output from all! Now as you have seen from my previous posts, I document. And I will continue to place doco and pictures of the strides I make as I expect everybody else to do. The last 4 days have shown great hope with the amount of people contributing. That is what it is all about. Put pics there. Even if they are half-cocked. Graham Bell found the working telephone device by spilling acid on his hand and yelling.
I use Visio2k for drawing. Get it, learn it. do it. Or hand drawn and scan. It's all good.
All for one, and one for all
Starcruiser, you mentioned the 555 timer to a current driver? Done. I have a single signal channel with a tip41 output running but thought the power from the truck would be totally 'Tool Time Tim Taylor' to do. I'd like to be the first one with 90's Tesla truck!
jdo300: Welcome aboard this current trend. Everybody sounds like they want a piece of this action and that is good. All of our different backgrounds will be of benefit.
Well now that I've got the pro-active ra-ra off my chest I can say I am truly glad to be here in such a time as this. My idea of this is as we do our independant thing we are actually doing the greater good. I do appreciate the circuit suggestions to what I've done. This is gonna be fun. Experimentation is what lies between dreams and reality. Experience is the knowledge along the way.
And remember, get your avatars updated with a design pic. Show and tell always wins. It shows positive action to a down trodden world.
Let's change the world, friends. 8) It turns another day without change.
Tesla said 'Rotating magnetic field'. Those words haunt me into doing. I don't want to remember those words if I have done nothing.
And Tao!!! Thank you very much! Mountains of doco to light the path. Something has to come of all this.
If some of you haven't seen the NASA alien videos, get on it. They are truly here with demostrations of different frequency powers!
I go to the VLA and Roswell this weekend in care of www.bisque.com. I feel like Richard Dryfus in 'Close encounters'! LOL
PaulLowrance
Hi tao,
Can you tell us where we can find these post by SM?
Thanks,
Paul Lowrance
Hi Tao,
great thinking !
If the Mark units are really working on interfence pattern
moving along and inducing output inside the core copper coils,
then why does he need 3 coils inside the core ?
Why not just one coil and just a few control coils wrapped around it
to create the 2 opposite rotating magnetic flux fields ?
So if it has nothing to do with the Barkhausen resonance in
iron wires, I still wonder, if this rotating interference pattern
will need additional input power, if power is drawn from the output
coils ?
I don?t yet see the dragless operation of this !
Also if you use antennas to draw power from a transmitter,
the transmitter needs to generate this power first,
so the antenna is able to draw it all from it.
So if the transmitter and antenna are coupled, then the power is
just transmitted from the transmitter to the antenna and that?s it.
You need to put more power into the transmitter, if you draw more load
wattage from the antenna...
