Quote from: -[marco]- on September 20, 2006, 05:40:49 PM
hi,
Before i run ito this website i was doing an experiment to see if it is possible to extraxt some power form a permanent magnet.
i started with something like fig1
then i thought about replacing coil 1 with a permanent magnet like fig2.
or even better fig3.
this couldnt be done because magnets are solid i thougt..........but i read in this forum someone said the were defenitly not.
seems to be something there.
now i also read somebody said if you somehow compress the magnetic field and let it "snap" (just cut the dc power fast) it would preduce a "kick" to about 100 times the power of the magnet.
maybe something there too.
but its just a thougt.......
greetz marco
Hi Marco, I don?t yet see,  how you can extract
more energy.
If you use a magnet with it you must use more electrical energy to
compress the field first. Okay, then it snaps back also more,
but only as much as you compressed it before.
This is the same circuit as Bill Alek?s Intalek Smartpack device.
But he saw now, that he can only get additional
electric charges, when he used 2 sparkgaps in series to
have additional electrons generated in the circuit
via somekind of electron clouds or "cold fusion" effects
at the spark gaps.
Same goes for Newman devices.
This seems to be the only way to get more electrons into the circuit loop
from outside and chargeup the batteries.
Maybe thus it would be best to optimize these spark gaps for
the most extrernal electon flow incoming via
mesh metal parts ectracting electron from electron clouds around the
spark contacts or special graphite surfacecontact points or bigger surfaces...
As Newman uses now 8 and more spark gaps in series for his new motors,
there he gets a lot of external electrons converted to fly into his circuit and
thus charge up his batteries.
Regards, Stefan.
Quote from: ctglabs on September 20, 2006, 02:27:15 PM
Stefan,
I have performed the test you asked me to.  I realise I should have connect the diode in that mannor in the first place, my error.
The noise is much reduced, but we can still see some positive spikes, and a few of them are at BEGINING of the Pulse.
Also, through all my tests I use a battery powered Fluke 123 Digital Scope, so there is always floating ground.
Dave
Dave, what kind of mechanical switch are you using ?
What contact material does it have ?
Can you change it to copper and graphite ?
Maybe just use a graphite pencil tip and some copper wire and see any differences ?
Quote from: -[marco]- on September 20, 2006, 03:12:34 PM
hi,
i do find it funny that they all seem to have that so called "optic illusion"
greets marco
Hi Marco,you are right !
Looks a bit strange !
Maybe it will indeed function best, if there is a small angle between
the coils ?
Maybe it is best for the local earth magnet field at Steven?s location to
extract the most power ?
PaulLowrance
For now we can only have theories about Steven Mark's device. Regardless where it gets the energy from there will always be heat generated by the current in the wires.
If I had but one request for legitimate "free energy" device inventors it would be the following ->
Please, could you please just get a simple 50 cent thermistor. All you need is connect the thermistor to a scope or multimeter. I have a $10 digital multimeter and a cheap thermistor that can measure temperate changes of just 10mW in a 3" iron toroid. In other words, if there is just 10 mW of energy being removed/added from/to the 3" iron toroid then I can sense it.
The thermistor only needs to make contact with the magnetic material. You can test both the PM or core in any experiment.
Hey, this request is on my Christmas list. :)
Paul Lowrance
Quote from: ctglabs on September 20, 2006, 02:03:21 PM
Ok, may questions to answer.
Quote from: hartiberlin on September 20, 2006, 01:22:21 PM
Hi Dave, do you get with your nice 4 coils on the toroid setup
now also this  rotating magnet field ?
http://overunity.com/stevenmark/toroid_gen.gif
The coils are bifilar, with to layers, I did not detect any movement with a compass so I do not think the field comes out of the core.  I have tried from 100hz, to 6khz, with single field, and counter rotating field with intereference signal.  Nor can I feel any vibration.
Please try at around 1 Hz only and see, if you can get the field to rotate inside the center as this:
Why are you using bifilar coils?
Just 4 normal coils will do it.
You have to setup each coil pair, so that
coil at 12 and 6 o?clock repell and
also coils at 3 and 9 o?clock repell,
but coils at 3 and 9 o?clock must be additionally
90 degrees out of phase to coils at 12 and 6 o?clock.
Then set a compass into the center and watch it spin at 1 Hz.
Instead of the compass you can then place an output coil into the center
and see, if you draw power from it, if the input power will rise ?
Try to orient the output coil in the center at 0 and at 90 degrees to the
other coils and see, what will happen.
Many thanks.
