supersam
giantkiller
Another dipiction where the circuit produces the harmonic wave at the tuned distance, the wavelength of the coil radius. Two views.
@sam, explain to me how you want Marco's previous toroid pic wrapped
mikestocks2006
Quote from: ctglabs on October 06, 2006, 06:33:30 PM
Quote from: mikestocks2006 on October 06, 2006, 05:38:02 PM
Hi Dave, do you or anyone else here knows if the SM toroid is with closed ends? (one continuous piece of wire? The 2 ends soldered or crimped together?) and then the out put is stepped up with other coil(s) inside that toroid?
As an example using the formulas for toroid with no added capacitors, and only its own self capacitance calculations, it results to a base resonant a frequency of  1.78 MHz
For the following configuration
Toroidal radius 10 cm (to centerline of coil radius)
Coil radius 2 cm
Number of turns 500
Air core
What would happen if the toroid is placed in a proximity of a field of approx 1.8 MHz?
Will the wires melt? Will it start ?kicking? if the pase is slightly off? Will the energy keep on building up inside the toroid?s field? To what levels?
To get to 7.8 Hz and with use of an external capacitor
An example configuration, calculates
External C approx 39mF
Coil radius 4 cm
Number of turns 1000
Air core
What that do it? Using a permanent magnet to start the first oscillation and then let the geofield take over?
Hi Mike,
I dont think it is close ended as SM has said it has control coils which are wound in segments around the torroid shape, it is to produce a rotating field.
Nice calculations though on working out the resonance for diameter and number of turns.  Guess it will be more complex with the segmented coils though!  A challenge!
I think you are right about the magnets being used to start the oscillation.  As there is no power input, then this can serve as a little kick start.
Dave.
Ahh ok. Thanks Dave.
After looking at one of the videos, the one with the most simple torus about 5" dia placed on the glass table, I thought with the old proven KISS principle the following could be a safe first assumption:
a. a closed loop energy amplification main toroid with a base resonating frequency of 7.4 - 7.8 Hz
b. a number of output (and possibly control) coils that can be
c. inside the energy collection and amplification toroid in different orientations?
   or
d. interwoven with the main toroid
   or
e. some of the output coils are actually part (sections of the toroid/spliced wires)
   or
f. some combination of the above
I was thinking closed end toroid since it appears to be self powering.
with possibility (e) one will actually remove current directly from the source without physically introducting another coil inside?
Just thinking out loud.
Thanks folks for a very interesting thread. Nice links, pics, info.
kames
Guys,
This web site does have a slow loading performance. If you want to get rid of it, just disable java script temporarily in you browser when viewing. However, when posting a message, you might want to enable it back, otherwise, some features might not work.
Just a thought -:)
Kames.
Hi guys,
yes, it seems there are now some problems
with the Ebay banners, as the sometimes quit loading.
You can just press the reload button in your browser,
then the page reloads quickly okay.
I will investigate it and try to get it fixed.
Otherwise you can disable the Javascript
in this moment.
@Dave,
great findings with this superimposed spike in the transformers.
How exactly was the setup for this ?
Did you use 2 transformers and just put their output in parallel
or did you feed just one tranformer with these 2 waves , only on different input  coils
on the one transformer ?
Many thanks.
Regards, Stefan.
