kames
Hi Dave,
The last posts in this forum are really amazing.
My post is an answer to your question and it is not related to the last posts here.
My set up for a bifilar coil experiment was next:
Equipment:
Function Generator, Oscilloscope with 1mv/div max sensitivity. Digital multimeter with ability to measure 0.0001 volt. Power Source Signal ? a car audio amplifier 300W. Frequency range was between 1 KHz and 15 KHz.
Coil:
Winding was done with 4 wires at a time, single layer, high quality coil, ferrite rod. Let?s number the wires from either side as 1, 2, 3, and 4. Assuming it, numbers 1 and 4 are representing the input bifilar coil. Numbers 2 and 3 represent output coil. In other words, the input coil are 2 wires outside and the output coil are 2 wires in the middle. The number of turns is 50. The wire type is 20G. At the other end the coils (1 and 4, 2 and 3) were connected in order to form two bifilar coils, output coil is in the middle of each turn of the input coil.
Testing for symmetry:
This is important. If the quality of windings is not good, you will be getting an output signal as a result of the asymmetry and not as a result of the HOOPER-MONSTEIN effect. How to test it? I had another coil wound on the ferrite rod. I powered that coil for a short time with about 70W signal and checked the signal in both bifilar coils. It was zero. When testing it, you have to load the output coil with some resistor, otherwise, you will be testing ?antenna effect? instead of real asymmetry/noise. I don?t remember exactly, but my each bifilar coil was 0.26 Ohm. The output coil was connected to 10-Ohm resistor to avoid any ?antenna effect?.
Results:
The set up was tested with the input power between 0 and 50W. The max output power was somewhere in the middle. With low input, it is obvious, the output was low too. With max input, the output was also low, which can be explain as increased cancellation of the magnetic flux because of the close proximity between each turn (4 wires) in the bifilar coils. The load was tested with a resistor between 10 Ohm and 1K. There was no difference in the output signal or input power consumption. The max amplitude of the output was around 0.5 V and was just enough to light a led.
Unusual:
When the output signal was connected to LC in series, the resonance was occurring with a very high hysteresis. The point of resonance was occurring far (higher frequency) after where it was supposed to be. When the frequency was going down, a perfect resonance continued to exist until the frequency was reaching the point far below the point of resonance and then abruptly disappearing.
Let me know if something wasn?t explained clear.
Kames.
gn0stik
Kames, you say you have a ferrite core.. Is it a toroidal ferrite core, from say, a monitor?
also, are your coils circumferentially wound, like antennas, or through the axis? I would assume through the axis since you are using a core.
Try replacing that ferrite with some garden wire, or speaker wire. ;)
It still won't be over unity, but you should see some stuff like Marco is posting.
giantkiller
As a reminder:
There are over 100 dead scientists so far who had the ability to speak.
One of them was the promoter of free energy, Doctor Eugene Mallove
http://www.zpenergy.com/modules.php?name=News&file=article&sid=738
How much you want to bet Tom bearden will be next. Anyone who speaks up will be shut down. Look, we all know the story about who thinks they can save the day ends their days.
No disrespect, Mr. Bearden. But we all know the costs and the enemies. Anyone pusuing this adventure can look at themselves as enemies of the state.
This thread has existed so far because of the safety in numbers. There is no such thing as 'Conspiracy theory'.
I wish us all well in this endeveavor.
I hate to post like this, but there are those that constantly say 'It can't be done, cause it would have already been done.' And I for one am tired of it. There are things far greater than our understanding that we have yet to come upon.
Gutenberg:
How many centuries did it take to get printed material?
Lister:
Operation using Lister's carbolic spray invented in 1869
Although his methods initially met with indifference and hostility, doctors gradually began to support his antiseptic techniques.
In 1870 Lister's antiseptic methods were used, by Germany, during the Franco-Prussian war saving many Prussian soldier's lives. In Germany, by 1878, Robert Koch was demonstrating the usefulness of steam for sterilizing surgical instruments and dressings.
126k abortions everyday.
tens of thousands starve to death every day.http://www.theradicaltruth.com/Footnotes/ff-starve-fn.htm
And these things can be done?
We are still barbarians... We so speedily stand behind doubt and avarice and kill the dreams of visionaries so quickly.
I will not be condemned by the status quo. Sorry to defile this thread.
--giantkiller, hence the name.
