HMM
found this interesting   http://www.vlf.it/FSR/FSR.html
A VLF receiver
EXTREMELY LOW FREQUENCIES RECEPTION  :o
The frequency range below 1 kHz is affected by many specific reception problems. Here we have a lot of hum noise: normally the principal quantity of hum noise is just there. We have less sensitivity of the antenna, because at so low frequencies the intrinsic capacity of the antenna becomes a super high impedance source and the adapting with the preamplifier became critical. Natural radio signal at ULF frequencies, like Schumann resonances, represents more critical reception respect whistlers, tweaks, statics and RTTY.
Besides the rain produces a lot of local hum noise below 500 Hz, caused by static field from ground to sky: when a storm cloud passes over our heads.
  Mike
mrd10
Hi Dave,
http://www.electricstuff.co.uk/oddosc.html, here's the link of that odd oscillator, that apparently is free running once started, this would be good to try  with the addition of a neg free resistor:-
http://jlnlabs.imars.com/cnr/index.htm, from his simple version using off the shelf components:-http://jlnlabs.imars.com/cnr/negosc.htm
Anyway its a thought
Cheers,
Dom   ;)
mrd10
Hi Dave,
ok sorry, Your definitely alittle way ahead of me here.
I was just thinking about sm's early videos, you know how he mentions that his device acts like a jet engine, i.e it winds up.
The middle coil on his first prototype could be part of an lc cct, just curious maybe we should try placing a magnet next to the odd oscillator cct to see if it makes a difference.
Cheers,
Dom  ;D
mrd10
Hmm, Quite right Dave, something else that sticks in my head about his initial videos, he says this is not a free energy device, rather a 'CONVERSION' device, so maybe all he is doing is pulsing with a simple 555 timer at a certain frequency, and possibly feeding this back into the coil setup he has. I posted a diagram awhile ago on something i found in one of my mini enginnering notebooks, and when i saw it, I was convinced in part, that what Steven marks has done can be related to this same article, only way to findout is to experiment with what we already know, Anyhow take alook at this dc to dc converter, I haven't been able to find anything on the web that comes close. If you do post me the link.
Oh also d/l this java applet i found, its got alot of cool simulations, which one of them is a lc cct.
http://www.walter-fendt.de/download/ph14dl.htm
This is all like looking for clues and trying different things, notice that the NDR from Doctor Chung was found out purely by accident
Ah yes  Technology - accident....lol
Dom  ;D
dutchy1966
Quote from: ctglabs on October 21, 2006, 08:44:39 AM
So we have a mix of frequencys and rotating fields, in normal terms this still won't couple to the collector!  So it cannot be normal EM interaction, its must be something else, radiant energy, longitudinal EM wave or something.  And lets say you have a 90 degree coupling that works, what will make it so special that it won't be subject to the normal losses of 0 degree coupling?  In other words, lets say you had a 90 degree coupling that worked, why should this be overunity?  Where is the extra energy coming from?
Lets say even that some frequencys can mix and create a larger amplitude which contains more energy, like the two sinewaves adding.  This still wont couple to a 90 degree collector.  So what is going on?
I think its easy to get carried away with so many ideas, we need to get back to basics!  How can we get a 90 degree coupling?  How can this be possible?  Perhaps when this is clear, the rest will become clear?  The rotating frequencys and mix must in some way create a situation which allows the impossible 90 degree coupling...
Dave.
Hi Dave,
As far as it being overunity I guess there are only two options:
1. Radiant energy (overunity like Gray = abruptly interrupting the current before it reaches the end of the wire)
2. EM wave adding (4x power)
There aren't any other options of violating the law of conservation of energy are there?
So, if that's the case then SM's device has to operate by one of the above principles.....
Seeing as there is a 90 degree coupling (which is for sure as far as i can see) it could only be radiant energy,RIGHT?
I must say that the wave adding to me sounds just as promising as the whole TPU itself, but that should be something for a seperate topic i guess.
You seem to think along the same lines, reading you recent posts......
Regards Dutchy
