0 Members and 34 Guests are viewing this topic.
Mr_Video
Quote from: ctglabs on October 22, 2006, 02:33:06 PM
Hi,
So kind of like a coiled up coil!  I can picture what it would look like, bit like Markovitch's later device but that uses a spiral, not a solenoid coil.
I am not sure what it may do, I will have to think about that!  Probably some complex induction!
Dave.
yeah, exactly !
you could probably do it with a steel or iron core if you could bend it (carefully) lol
kind of a coil shaped like a Helix .
fcpeace17
my post was lost in the horrible quote i did but bassically my question is, if you have 2 coils A and B and they are resonating to create spikes, then the resulting spike resonant frequency is a harmonic of a third coil (which may be tuned to an earth frequency) which will cause a 2nd climb in amplitude. Then say that final amplitude jump is a frequency that resonates one of the original A or B's or both, it seems like  this will credate a viscious cycle. sorry for the not so good description. Evan
mrd10
The tuning fork that i showed a couple of posts before, resonantes at 329.6hz, we could test this on oscilliscope.
The number is actually written on the fork itself, and is the musical letter E.
I will goto music shop today and get musical letter A, to see what the freq is and see if the spacing or the lenght of the fork makes the difference.
Again tuning into resonance freq, I think is the key here. I'll keep you guys posted on my findings.
Cheers,
Dom    ;)
starcruiser
Kosh,
I re-did my experiement with pulsing my torrid via the control coil and observed the same results as you, a ringing waveform in the large coil. Just validating your experiement since I had also experienced this before.
Carl
starcruiser
Kosh,
I have to post this seperately since the website timed out, might be due tot he size of the pix. The input frequesnct was about 200khz and the resultant ringing was close to 1.8Mhz, see pix.
Carl
