giantkiller
Quote from: dean_mcgowan on November 05, 2006, 07:29:45 AM
is there a post somewhere i missed .. because everyone has left and there is some kind of claim they have a working model and half the posts are missing .. can someone please explain whats happening here .. ?????????
A single event Implosion. Suicide. The answer wern't coming fast enough? I guess the majority did not see the total value of the positive implications. I fired off a message to Stefan to put up a duplicate locked thread from a backup. We will see.
Lindsay: Thanks for the safety message. Once I saw lightning strike an oil filled tranformer up on a Tele pole. It exploded, shot into the sky maybe 75 feet and was totally obliterated. No large peices of metal fell to Earth. The flash was like a 150lb xenon bulb.
Thanks for staying on board. If I can be of any service let me know. Also, are my pix anywhere close to the solution? I don't want to head down the wrong way too head strong. And it would be nice to be affirmed.
When things breakup, those who refuse to abandon the cause at times take on remorse and guilt. It is natural to do. This post lost alot of talent.
--giantkiller. Sigh.
giantkiller
Quote from: pese on November 05, 2006, 08:02:20 AM
For Stubbelfield /Mc Farland Patent following : .
I find my datas (written from me in german 3years ago...)
Winding details are 65 to 23 windings
here my german txt with more details:
Kochs Daniels McFarland Elektromagnetische Batterie
Hundert und drei?ig Jahren vor Koch Daniels McFarland aus Mansfield,Ohio
patentierte Dieser  eine "elektromagnetische enrgieerzeugemde Batterie"
Er gab an, da? DIESE:"Einen konstanten Strom ohne Fremdenergie wie,
z.B. einer galvanischen Batterie, produziert".
Sein Patent Nr. 119.825 wurde am 10-10.1871 herausgegeben.
Dieses war, acht Jahre bevor Edison die Gl?hlampe erfand.
Man vergleiche die zwei gegeneinander gekoppelten Spulen mit der Anordnung
der Testatika und des Hendershot wie Coler Generators.
Das Wicklungsverh?ltniss ist 65 Windungen und 23 Windungen
Es ist  wichtig, da? die Sekund?rspule an in der gleichen Richtung
wie die Prim?rspule gewickelt werden muss.
Der Eisenkern A kann ein fester Stab oder ein B?ndel Eisendr?hte.
Je feiner die Eisendr?hte sind, um so h?her wird die Ausgangsspannung.
Die Lastwiederst?nde sollen ca. 16-30 Ohm betragen.
Die Ausgangsspannung kann bis 3 Volt betragen.
Der Generator wird durch eine externe Gleichspannung, gepulst,
gestartet
http://pixerve.de/43323/pese.html
Translated for everyone @ http://www.humanitas-international.org/newstran/more-trans.htm
Cook Daniels McFarland electromagnetic battery Hundred and drei?g years before cook Daniels McFarland from Mansfield, Ohio this patented a "electromagnetic enrgieerzeugemde battery" it indicated, da?DIESE:"Einen constant river without foreign energy as, e.g. a galvanic battery, produced". Its patent NR. 119.825 one gave change to 10-10.1871. This was, eight years before Edison the Gl?ampe invented. One compares the two coils coupled against each other with the arrangement of the Testatika and the Hendershot such as Coler of generator. The Wicklungsverh?niss is 65 turns and 23 turns It is important, da?die Sekund?pule in the same direction as the Prim?pule to be on wound must. The iron core A can a firm staff or a B?el Eisendr?e. The finer the Eisendr?e is, the h?r becomes the output voltage. The Lastwiederst?e is approx.. 16-30 ohms amount to. The output voltage can amount to to 3 V. The generator by external DC voltage, one pulses, one starts
This had been posted before. Again I say this very similar to a Tesla coil. 3 coils imbedded in each other, larger wire on outside, smaller wire inside.
--giantkiller.
giantkiller
There will probably be more sequencial postings by any single poster for a while till the grop builds again.
I refer to patent 119825. http://www.pat2pdf.org/patents/pat119825.pdf The coil build is similar to SM coils.
I refer to patent 390721 http://www.pat2pdf.org/patents/pat390721.pdf The N/N1 coils in the transformer are crosscoupled like the Cook patent 119825.  In fact the transformer N/N1 coils are dual Daniel McFarland Cook coils.
I refer to patent 382282 http://www.pat2pdf.org/patents/pat382282.pdf. Figure 1 is the patent 390721 transformer. Looks like the 2 large black SM coils. And there is even 2 conncetion places for dual freqencies. This xfrmr is also crosscoupled.
So we have a iron center, small guage wrapped around that, then a large gauge around that.
I am not saying that the iron center makes our attempts with air core incorrect. I am saying that the pattern all points back to previous posts.
--giantkiller. ;)
pese
Quote from: giantkiller on November 05, 2006, 11:29:11 AM
--giantkiller. ;)
Tank GK
I have changed son misstranslated words.
Noewi its better to understand.
Pese
[/quote]
Cook Daniels McFarland electromagnetic battery 130  years before cook Daniels McFarland from Mansfield, Ohio this patented a "electromagnetic power-producing  battery" it indicated, da?DIESE:"Einen constant river without foreign energy as, e.g. a galvanic battery, produced". Its patent NR. 119.825 one gave change to 10-10.1871. This was, eight years before Edison the Lightbulb  invented. One compares the two coils coupled against each other with the arrangement of the Testatika and the Hendershot such as Coler of generator. The Ratio of Wire-turns s 65 turns and 23 turns It is important, because the primair coil in the same direction as the Primair-Coil to be on wound must. The iron core A can a firm staff or a bound of ironwires . So finer the Ironwires are, so higher comes the output voltage. The Load-resistors are.. 16-30 ohms amount to. The output voltage can amount to to 3 V. The generator by external DC voltage, one pulses, one starts
--[/quote]
raburgeson
I think transformer gas is safe to use, but it will not solve the heating problems. The heat is internal, the reactions in an L,L circuit are almost without resistance. One problem we are having is none of us are schooled in L,L circuits and I approached this project with considerable fear to begin with. I don't think they made a convenient bail out. I think they melted a fair amount of copper very close to their unshielded faces. I can't say much on L,L except 2 inductors go 180 degrees out of phase and can produce positive feedback. They can resonate and amplify. Not even the engineers in this or any other group have a solid educational background in this. I hope noone is badly burnt and the world needs this so we must plod on. You can get fried by most of the projects on this site. Even if you quit to work on something else, be careful, under the right circumstances a car battery can stop your heart.
I used copper multi strand copper for the collector cores and my output looked promising, however even under the lightest loads the voltage fell from 84.02 volts to about 2 volts. I'm considering what was posted by Giantkiller, and others just now. I don't know about the turns ratio 65:23 but I think I might try to find insulated multistrand magnetic wire. If I can't find it I got some friends at Sun electric that might be able to make me some. Or maybe if I just re-wrap this thing. One thing seems for sure the output is from a section 90 degrees from the input. Right now I have 24 turns in each section. It would be good to look at the insulation anyway, got pretty warm. Good luck guys and don't give up.
