Automan
Quote from: hartiberlin on June 14, 2006, 08:55:55 PM
?s there any documentation on the web about pulse exciting iron wire coils ?
Has somebody else already confirmed, that iron wire coils have no Back EMF effect ?
Of course they do! Plus eddy currents, and  anything any othr flux material suffers from.
Konehead does a lot of playing around with pulse motors, and iron wire for some things, maybe you can find some usefull information on his page.
This link is for building  very efficient neo-mag generator, but just click back to his main page. I think he uses iron wire coils to pick up stray back emf and feed it back into his pulse outboard motor.
http://www.geocities.com/koneheadx/RVMuller.html
Ooops.  That's not what you were looking for.
I was thinking of This :http://www.geocities.com/koneheadx/splatterenergy.html
Which is how to pick up Flux "splatter" and feed it back .  Steel core coil, not steel wire.
Still, it's a good tip
Automan
Quote from: tao on June 15, 2006, 01:52:37 AM
Quote from: Automan on June 15, 2006, 01:48:49 AM
And no "DUDE",  you did not find anything to coroborate "his" principals in conventional science.
In fact, you can't even provide a diagram.  he's got you "thinking", and I'll bet  not one of you are actually "thinking" of the same thing.
have you eve noticed this person reads the forum, but never replies on it himself, but goes through a "friend"?
Read the other fantastic invention story. Maybe you will "see"  the light.
Even if this whole thing was bunk and bogus, I know for a fact that me and gn0stik could give a crap, because we already learned some amazing things in our process of looking at this 'fake invention'.
I thank you for your concerns, I really do, but I feel that they aren't warranted in this thread.
That's all well and fine.  I was just warning you, there was no need to be rude.
I never said this guy was stupid, just a player.  He's probably reading  http://www.rexresearch.com/1index.htm and feeding you  interesting things that are sort of relevant, but in the end, they all add up to nothing.
Anyways, carry on.  You'll find this same sort of thing(but a different story) on many sites.   It's all well and fine, until they con someone out of cash. then it isn't funny anymore.
bob.diroto
Hi Mannix,
Any comments on the posts to this forum in the last week or so ?
Are you still in contact with Steven Mark ?
bob.diroto
The old rotating compass.
Been thinking about the compass. A compass is placed within the space in the center of the toroid. The unit is started and the compass starts to speed up, until the unit gets to maximum power where the compass stops rotating. When the unit it turned off, the compass starts to rotate again and then slows down and stops. It's been commented that there is a jet engine turbine effect.
These are the only reasons I can think for this effect:
a. The magnetic field stops rotating.
b. The magnetic field ceases to be.
c. The magnetic field moves away from influencing the compass.
d. The magnetic field is spinning so fast the compass needle can't get a hold.
I don't think a. or b. are realistic, the compass does start rotating again on slow down.
I find it hard to think d. It's like saying that you can't feel a 200km wind because it's going so fast. If the magnetic field was there you'd get rotation of the compass even if there was a lot of slippage.
But we know the device has inertial effects. And like a tornado the eye has no movement.I think that whatever field is set up has vortex like effects which as it speed up causes the center to be void of magnetic fields, which is 'c' above. Something like a spinning electron field!!! (Hello Mr Mannix thanks for that clue in your last post!)
Incidently I think the first devices created by Steven Mark relied on self-resonance and tuned coils only. With them tuned in to the magnetic field of the permanent magnet which we are assuming, with good reason, to be 173.9 Khz. Extracting energy probably proved to be difficult because variable resistive loads will change the resonance. i.e. You'd have to tune your device to the expected resistance. And if the resistance changed over time (like a heating lightbulb filament might change resistance) you'd probably pass over the exact resonance point and boom your device dissappears in a mass of smoke and copper....
Once he understood the nature of what he was tapping into - and I'm summising the unknown field is spiral (helical) in nature - he was able to create advanced devices. It is these later devices that exhibit the spinning compass effect.
On later devices I believe he was able to directly create the required frequencies and thus not have to rely on tricky positive feedback loops which can get out of hand. If you want to tap into a spiral electric field you need to create a circular polarising waveform. This is what the four coils we can see are for, I believe.  The coils would be oriented vertically - with pole going up/down - with a sine signal applied 90degree out of phased. For info. on circular polarisation see http://en.wikipedia.org/wiki/Circular_polarization
It is the electric field that spirals and the 'kicks' generate electrostatic effects. Patrick Flanagen's device was an Electron Field Generator.
gn0stik
Quote from: Mannix on June 15, 2006, 04:11:38 AM
Sorry, I should have mentioned that I have heard very little from Steven of late.
I had drawn his attention to the current thread yesterday ,hoping that he might want to add to the entheusiasim  but i feel that when he sees the rubbish of late he may understandibly shrink away.
He really liked Dr Morays speech
For those who find my attitude annoying I would like to point out that it is a very fine line between copying and discovering and I do find it frustrating going over what was clearly emphasised previously.
The reason that he has chosen to work thru me is that it insulates him from the stuff that comes from time to time . Many times he has said that he will never look here again.  As far as he is concerned he has given us what it took him 10 years to discover. He has also shared the inspiration as well as the fact that the actual source of the energy is not clearly understood . Perhaps tesla understood it. I urge you all to experiment with the head start that he has offered.
I think it unlikely that he will post a diagram but I am sure that he will encourage understanding. This involves people being hands on. I do not know what will come of this but the process is worth contributing to and I urge people with a positive attitude to stay with it ..as for the others they should just watch.
They have nothing to lose and nobody wants any money!
If you think that this is a game then simply do not play if you dont want to but Please try not to  make something both fantastic and hard, even harder for those with the courage, who dare to stick thier head into this.
End of annoyance
Sincerly
Lindsay Mannix
So Im not sure who will be offended by what. But I am sure that Steven would be offended by the rubbish. Perhaps he is too sensitivor perhaps he is just completely unimpressed.
Welcome back Lindsay. I hope you didn't take the comment I posted about you the wrong way. I have to admit, I used to find you fairly annoying, and had a lot of questions about your presentation tactics, and the way info has been distributed here. At any rate, I've been working hard to understand the principals you've laid down for us in your parable, and prior to that, and I think we've hit on some important principles here. Whether Steven Discovered, or re-discovered, or simply implemented, is of no concern of mine, I will still give credit where credit is due. I'm perfectly aware that in many cases principles have been discovered by many people in a very close time frame. I sure would appreciate some validation of what we've been talking about as of late. We can still move on without it, as I'm relatively sure we've hit on some good info. Heck, perhaps Bill got his info from Steven.  My biggest worry at the moment, is that knowing how dangerous it is, what kind of precautions should we take when implementing. How to SAFELY implement. I don't want my first attempt to go runaway, and start zapping me from across the room. We WILL give this a shot very shortly.
