Sjack Abeling Gravity Wheel and the Worlds first Weight Power Plant
Started by AquariuZ, April 03, 2009, 01:17:07 PM
mondrasek
@eisenficker2000,
This model is much more difficult for me to do correct vector diagrams on than the earlier one of the sim that I did.  In that earlier one I was calculating the vectors on spherical weight where the guide and slots were in contact with the OD of the sphere and the correct vector angles were obvious.  When we look at your analysis where we holding the weights at their CoG, the angle of the slots becomes much less obvious.  I looked at it several times and had convinced myself that your method was correct for that ideal case each time.  It was only when Omni's analysis of the complete 45 degrees of rotation gave unexpected results that I was able to realize how we were missing the angle of the slots.  And in my recent exchanges with Omni it is ever more clear to me how tricky this case is.  And that is why I love gravity wheel concepts.  Though they seem so simple, there is a lot to be learned in order to understand them.
I am still curious why this design will keel if supported at the CoG of the weights.  I believe it would be due to either 1) energy input to the system when the guides are installed (similar to why the CoG of the system is not coincident with the axle), or b) due to the fact that there are two different angles in the slot, or c) something I have yet to learn or consider.
M.
eisenficker2000
@Mondrasek Yes, the vectors are much more complex and confusing in the end..
I wonder what the effect is of curved slots, like Dusty is using.. And no too much work to calculate their effects.
I am trying to make a simple computer animated model (in VB). One weight only, but the geometry of the track makes it already challenging. Let alone to get all the vectors and their geometry. And I am already leaving out the dynamic part....
Omnibus
I think you should not now try to twist the whole thing every which way to appear you're right. You now understand @eisenficker2000's method is the correct one. Let's move on.
Omnibus
Quote from: eisenficker2000 on May 16, 2009, 06:07:01 PM
The dynamic part should, of course, be left out. The wheel may be made to turn very slowly (to avoid talk about centrifugal and centripetal force) and yet make full turns which is the gist of the phenomenon.
Now that we have definitive proof for the reality of the phenomenon, optimization is in order, indeed.
i_ron
Quote from: Omnibus on May 16, 2009, 06:45:27 PM
No definite proof has been shown... only mistakes in math.
Ron
