Cherryman
Quote from: Omnibus on April 14, 2009, 07:07:33 PM
Now, @Cherryman, you're really sinking into this which is getting to be frightening. The MiB's are really gonna get you this time. lol.
Listen, let's first "replicate" Abeling's patent as close as possible. I'm way off at the beginning of the AutoCAD learning curve, so won't be of any help any time soon. Can you draw the wheel exactly as it is in the patent and then affix it to the barrier of your device EF2000.wm2d? That'll be a good start.
I have seen so may things come by , you will have to show me again wich of Abelings drawing you mean (He ahas a few different ones i belive?) And I will have to look if i can still find (reproduce) the EF2000 swtup.. I do so many things.. it's getting a bit disorganised.
I will see what i can do.
I don't like replication, because if the clue is there then others will notice, so i follow my own path. Sure sometimes i see things from other designs wich are usefull, but i don't really study the designs, i simply look at them and decide on instinct if it has something or not.
When creating them myself ofcourse there will be influence from what i have seen from others, but by re-inventing it myself i think i might find different approaches or angles.. and i'm stubbern!  ;D
fletcher
Quote from: Omnibus on April 14, 2009, 07:17:11 PM
@fletcher,
Where do you actually click to do that, especially to control the number of frames? Also where are the data located to export them into Excel?
<File>Import/Export     .....    <World>Accuracy>More Choices
Often if we have something of interest we build a physical model & then back engineer the sim to the same dimensions & mass values etc [or as close as reasonable] - then we adjust pin frictions etc until we get a close alignment between real & predictive sim behaviour, as a further cross reference for reliability - so far the behaviour always lines up but I put that down to his skill  ;D   !
Omnibus
@Cherryman,
Well, it's usual patentees to hide some crucial aspects of the device or the method so that they can control further negotiations through trade secrets. I don't think this case is any different. It's worth I think for the time being to have the device "replicated" in wm2d as close to the patent as possible. See attached Fig.2 from Abeling's patent and the two examples of wm2d (especially one of them) closest to the patent.
Cherryman
Okey, so you want this design with the blocks from EF2000 , i will see what i can do....
Here is a teaser to keep your mind bussy in the meantime:
http://www.youtube.com/watch?v=tPgezU4ql58&feature=channel_page
If you do some force analysis you can get an idea why these ramp setups won't work. That patent is a joke. Any design that uses a ramp now is patent infringement, that's how vague his patent is and I'm pretty sure is deliberate.
