Stator and Rotor how to make help needed!
Started by infringer, April 05, 2009, 10:25:18 PM
Michelinho
Hi Cityguy,
Nice drawings, it is indeed worth a thousand words.
Thanks,
Michel
clflyguy
This one lets you pretend you have xray vision, as you are looking through rotors, stator, split barrels and one of the plywood separator discs..
As far as the stability issue is concerned, you will need another hub at the top with a center pipe going up the middle to connect them. This is
about the only way to keep things from rapidly getting out of hand.
clflyguy
This is a look at one of the brake rotors superimposed on the stator. The trailer hubs with stub axles have stubs that are square or round, get the square one for ease
of welding the stator support struts to.
clflyguy
Last one,
  Here is the top with the second hub, once again you can see how useful the square stub is for welding on the extended brackets for
the guy wires. In all seriousness, you could make the alternator in three evenings and the vawt over a weekend.
infringer
The list the amperage and volts the thing puts out but there is no wattage curve which is what I am interested in ...
If the barrel turbine puts out more watts I figure why waste 440bux been thinking while I was out cleaning the garage I guess I'll have to do the math here...
5MPH
.2 amps
20 volts
10MPH
.4 amp
23 volt
15MPH
1.5 amp
42 volt
20MPH
3 amp
60 volt
25MPH
4.9 amp
72 volt
30MPH
7.5 amp
92 volt
35MPH
9.5 amp
104 volt
40MPH
10 amp
118 volt
45MPH
11 amp
120 volt
That is simply for the ready made jobber....
HOLY MOLY!
EUREAKA! I think we are one to one hell of a project there cityguy too sweet!
I have one issue though I am only able to get two barrels at the moment but I will most likely be cutting them in half tomorrow providing Easter Sunday is not to hectic my grandparents will be down in a week to spend the summer with us as well but there is no kabash on this project....
So I have barrels that are supposed to arrive tomorrow hope that materializes and I get time to cut them in half! But my coil did come in the mail 11lbs of it!
REGISTER AND BECOME A MEMBER RIGHT NOW!!!!!
........::::::::: http://www.energyinfringer.com  :::::::::........
"""""""everything is energy and energy is everything""""""
-infringer-
