HHO explosion slowing down the burn speed of HHO to get compatible with gasoline
Started by hartiberlin, April 18, 2009, 05:19:02 PM
hartiberlin
Hi All,
we had the question of how to modify the ignition of a backup power generator
for the explosive HHO gas.
I guess we can spare this modification and just do the following:
With some additions to the tricks shown by Youtube user:
http://www.youtube.com/user/Hollywoods7
so that we not just put the additional air just into the bubbler,
but directly into the electrolyzer, we can manage to create a very slow burning mixed air + HHO gas.
A few years ago I saw a video from a guy, ( before youtube was born)
who had mixed with an aquarium airpump lots of air into a Y-hose together
with very little HHO coming from his small electrolyzer.
The flame which came out of his air and HHO mix hose was burning very slowly
and was not explosive at all.
It reminded me of the flame of just gasoline or a candle.
I guess it is the best and easiest way this way to feed additional air
directly into the electrolyzer to generate already there the mix of a
nonexplosive gas mix !
This way also the HHO bubbles will come off easier from the stainless steel
plates and this also could make the HHO celll more efficient,
but the biggest plus would be the won safety factor !
So get yourself a 12 Volts electrical air pump and pump as much air into
the electrolyzer, so that the HHO and air mix gas will be burning really slow.
Then you can feed this directly into your AC generator and you will
not need any ignition modification.
Surely you have to make sure, that your airpump
will not fail, so there could be made some circuitry, that
checks the airpump for failure and switches off the electrolyzer,
should the airpump ever fail.
Happy building !
Regards, Stefan.
d3adp00l
Why slow the burn rate to run in an engine not designed for hho?
That would be like running coal in a gas engine
History is full of people who out of fear,
Or ignorance, or lust for power have
destroyed knowledge of immeasurable
value which truly belongs to us all.
WE must not let it happen again.
-Carl Sagan
hartiberlin
Quote from: d3adp00l on April 18, 2009, 07:08:30 PM
Just to see,
if it is possible to close the loop and thus only run the whole system on water only.
The slowing of the burn rate might adjust the air plus HHO gas mix this way, as if it would
be a gasoline-air mix.
Just get the mix relationsship right and you don´t need to modify your power generator.
That is the huge advantage and the gas which comes out of the electrolyzer would
also not be anymore explosive so easily.
So you also could avoid using a Flashback Arrestor !
So it would also give you advanced safety.
Regards, Stefan.
4Tesla
No.. slowing down the burn to the same rate as gasoline.. HHO burns too fast.
4Tesla
