HHO explosion slowing down the burn speed of HHO to get compatible with gasoline
Started by hartiberlin, April 18, 2009, 05:19:02 PM
0 Members and 55 Guests are viewing this topic.
Paul-R
Quote from: chessnyt on May 13, 2010, 11:12:20 PM
This question is for whoever can field it:
Regarding engine operation; there are a lot of youtube videos (as well as other HHO site resources) that state that igniting HHO in the cylinder causes a suction (implosion) and therefore pulls or sucks on the piston and draws it towards the cylinder head.
Its all about spark timing and wasted spark (for two strokes).
try this:
http://www.free-energy-info.co.uk/Chapter10.pdf
Page 50, amongst others.
Cherryman
Regarding engine operation; there are a lot of youtube videos (as well as other HHO site resources) that state that igniting HHO in the cylinder causes a suction (implosion) and therefore pulls or sucks on the piston and draws it towards the cylinder head.  Then there is also a lot of videos and the like that claim the ignition of HHO gases in an ICE cylinder causes the gas to explode and pushes the piston away from the cylinder head in the same way gasoline would.  Could someone please tell me which is the case?
Many thanks in advance,
Joe
Hi Joe,
actually it is both true.   First there is an explosion, followed by an implosion.  From my test i concluded that the amount of air is almost equal.  Although it looks like the implosion uses a little more.
I suspect that it is equal by size, but due to heat losses outside the balloon and chamber, into the materials etc.
I think the explosion is a "sudden moment of immense heat" and all the pressure and air effect is just nature restoring balance by equalizing that heat with the ambient.
The explosion is much faster as the implosion (or some might say : cooling air)
http://www.youtube.com/watch?v=tBHapR2lT0A
As you can see, the balloon after the explosion is less filled then before.
Cman
mscoffman
I think this business about HHO suction is a bit ridiculous.
Obviously the density of water H^2O is greater then the
density of HHO per unit volume simply because HHO is a gas.
So you are going to get suction if you burn a stochiometric
amount of HHO. There no equivalent setup when you burn
hydrocarbon (unless you burn a CO carbon monoxide plus
hydrocarbon fuel mix - and then please, not around me).
There is no preliminary to CO^2 gas, it's all emitted.
Air, on the other hand, is 70% Nitrogen and except for very
small amount of nitrogen (forming the pollutant NOx) the
nitrogen gas is almost like a noble gas to the combustion
process. It simply passes through the combustion reaction,
but is does interact as a perfect gas volume to heat in
the Carnot cycle. But ICE engines have design
parameters to breath air
!, so getting a small amount
of suction is to be expected if an ICE engine gets all of it's
energy from Hydrogen...and a larger amount if it's not
allowed to breath any extra air along with the the HHO.
If you don't like it, then design your own pure
hydrogen+oxygen stochiometric mix fuel powered internal
combustion engine...you will need to anyway, if you want
reliable long term operation.  As I've said previously I know
what I am saying is correct because you never hear of a
pure oxygen aspirated engine. Nitrogen must add something,
even if it just slows down the combustion process because
it forces the combustion to scrounge oxygen and I think that
something is the perfect gas volume from heat temperature
conversion.
So yes there is suction on the exhaust cycle which cools
the engine down...that's is why it makes some sense
to use hydrogen as an additive to hydrocarbon fuels.
And if mix is done via a computer to have it look at
engine temperature when determining the mix. Pure
hydrogen pulls the engine temperature down and
hydrocarbons could boost it back up. That's why during
WWII there was a "War Emergency water injection
switch on certain ICE fighter aircraft". One switched it
on to increase performance but it also tore the engine
up, so it was not used long term.
:S:MarkSCoffman
sushimoto
Here are some experiments to find out if there is any expansion
during the reaction of pure HHO under atmospheric pressure.
If you watch carefully, you will see that there is no
expanding gas leaving after ignition.
http://www.youtube.com/watch?v=HgnD8xJy4Kk
(at 1:00)
If the HHO is slightly compressed, it will expand a bit, but not significant.
If you mix it with air, or any other "thermic expanding molecules"
then expansion occurs prior to suction.
(volumetric reduction, suction, implosion)
http://www.youtube.com/watch?v=soEwvDuPi3U&feature=related
Hope this helps a bit clearing the issue.
best,
sushi
DAMIT DAS MOEGLICHE ENTSTEHT, MUSS IMMER WIEDER DAS UNMOEGLICHE VERSUCHT WERDEN.
