What does a "kick" look like on an oscilloscope?
Started by Grumpy, April 29, 2009, 09:51:01 AM
Grumpy
Does it look like the attached image?
        -Frank Edwards
Grumpy
I'll take the "silence" as a "yes".
Thanks Much
        -Frank Edwards
MACEDONIA CD
hey
i see HERE RESONANCE
THE KICK MAST BE WHITOUT RESONANCE
CLEAN  :)
Grumpy
Quote from: MACEDONIA  CD on April 30, 2009, 05:21:26 PM
hey
CLEAN  :)
The appearance depends on what you are doing and how you are looking.  The image here is of a burst of oscillations - not resonance.
On an oscilloscope, that is several kicks.  The "kick" is an oscillation on an oscilloscope and an anomolous signal that may spread across a range of freqencies when viewed on a spectrum analyzer.
I have been seeing this for a long time, without knowing what it is.  The "kick" is right in front of me the whole time.
        -Frank Edwards
pauldude000
@Grumpy
First of all, I want you to know that I am not trying to start one of our (in)famous arguments.  ;D
A simple problem exists, and that is one of definition. Without a definition of exactly what a "kick" is, any spike or oscillation could be claimed as one on a scope shot.
At this point, we could truthfully have ten thousand claims about what a "kick" is, with its associated screen shot demonstration, and it means nothing unless it is the effect SM was describing as a "kick". If SM referred to older usages of the word, then a kick has to do with current.
If he was using a home-brew, self imposed definition for the word, then we might as well drop the concept of proving the "kick" until further information becomes available, as we will never truly know for certain.
Similar to Mace, I see simple oscillations which may or may not be aberrant, and may have a multitude of explanation.
Notice that I am NOT stating your observance of irregular oscillation is irrelevant. What I am saying is that there is no way to prove whether they are in fact SM's kicks.
They probably do contain great significance.
SM was none too clear, as he directly referred to a document which described the kick as an inrush current, then spoke of the kicks as if they were a voltage based phenomena and not a current based phenomena.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
