Weightless Weight
Started by Alexioco, May 01, 2009, 05:27:44 PM
0 Members and 23 Guests are viewing this topic.
gurangax
Nice since everyone here is interested working with pulleys configuration, I will also post my find later I found it to be very interesting because I think this one is never taught at school.
Alexioco
The footage is too big to fit on here, so you will just have to take my word for it.......
I tried a little test, if the bottom pulley is not far enough down, then it is not as effective, this is I think why you are getting negative results, but what mine does is, when the seesaw is straight, it balances and you can even face the seesaw down just slightly and it still balances, when you push down on the other side of the lever, it lifts the weight up slowly but easlily, and it doesnt go down at any point unless you push it down.... If there is anyone with doubts to my claims then I'm afraid its tuff luck to put it bluntly.... There is alot to learn from this device for those who are willing to learn... the position of the string and the length  of the string on either side determine how much more power there is one side than the other etc etc... I will leave this with you to speculate at :D
Alex
The love of God is great and true,
A special thing for Him and you,
A perfect friend, a Father too,
Lift up your hearts for He is true.
overtaker
Alex,   In your test,  what was the connection at the  " t " ?
Is it a bearing?  If you are using small weights and there is
lots of friction at the lever connection than that will throw
off the results!  For this kind of test that connection needs
to be nearly friction free.  imho   :)
Alexioco
Quote from: overtaker on May 03, 2009, 11:09:09 AM
Hi overtaker, the entire thing has harly much friction, the seesaw does not come in contact with the stand, do you want to give me your email address? we can disscuss it there, I have some things you might take a fancy too...
Alex
Lilhawk
Alex...sorry to hear your having problems with getting the file/pic/vid  posted
if you don't mind I be interested in those figures I mentioned about earlier
when I did my tests I just pulled on the load string.  When you have a balance the load weight will not matter.
