Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
baroutologos
@ Inventor,
IS THERE ANYTHING YOU HAVEN'T TRIED YET? :)
Regards,
Baroutologos
ps: Motor arrived, machining #2 on the process. In about a week i am to be operational :D - ΠΕΡΙΠΕΤΕΙÎ' v2
CRANKYpants
Quote from: wattsup on June 30, 2009, 11:38:55 PM
Some more questions. Sorry if these have been asked before but it would save alot of time looking through 4?? something pages.
What magnets are you using?
Is there a standard build spec anywhere?
Did you ever put your scope on a shorted coil while in acceleration mode?
70 lb PULLING WEIGHT, 1 " MAGNETS FROM K&J MAGNETS
NO SBS
NO SHORTED - BUT ON LOAD YES (CAN A SCOPE READ A SHORTED COIL?).
THOSE COILS HAVE BEEN AROUND FOR MORE THAN A YEAR.
THE BOTTOM PHOTO WITH THE RED COIL AT THE TOP IS MADE WITH L BRACKETS FROM HOME DEPOT AND IT WORKS VERY WELL.
THE OTHER COILS ARE VARIATIONS OF THE SAME THEME.
THAT SQUARE YELLOW COILED TRANSFORMER WOULD WORK WELL WITH TWO ROTORS I BET.
HAPPY CANADA DAY TO ALL!
T
wattsup
@TH
'NO SHORTED - BUT ON LOAD YES (CAN A SCOPE READ A SHORTED COIL?).'
Yep. Just put the one probe one the connection but maybe set the probe selector switch to the 10x level first. If you can't see anything, then put it to 1x, It would be really really nice to see how the wave form is when the rotor magnets hit that shorted coil.
"THOSE COILS HAVE BEEN AROUND FOR MORE THAN A YEAR."
Geez I was wondering how could someone work so fast.
"THE BOTTOM PHOTO WITH THE RED COIL AT THE TOP IS MADE WITH L BRACKETS FROM HOME DEPOT AND IT WORKS VERY WELL."
Yes I noticed those and also the way your turned the core laminations to follow the direction of the magnet travel. This magnet travel versus laminations means a dual-coil could not be used from one top to one bottom magnet since the laminations risk being perpendicular to the magnets travel. So the only real way of using them is if one side is at one magnet and the other is at the next magnet or the third magnet away if they are NSNSNS.
LarryC
Quote from: wattsup on July 01, 2009, 01:05:13 PM
@TH
Even better, if you could scope voltage, current and magnetic polarity on a HV coil/core while in acceleration mode. This would prove it is working as you clearly explained in reply #224 and eliminate any more speculation about the cause of the acceleration. Then all could just focus on replicating and enhancing that effect.
Regards, Larry
