Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
hydrocontrol
Quote from: wattsup on June 15, 2009, 01:40:01 PM
@i_ron
So, @i_ron, I do not see why you should leave the thread when you are the one that started it. We started this thread because @TH was not heard from for over a month and wanted to leave his thread alone. So just stick with it will y'a. Besides, I have a whole load of questions that need to be answered that have not been answered thus far.
I would agree except what is the point when someone with moderator privileges deletes post even if the thread was not started by that moderator. If possible Stefan should set this thread so only he can delete post or maybe Stefan should review Thane's moderator privileges.
I also agree that future information from Thane might be tainted since Thane is going in the commercial direction and it would serve his purpose to limit information.
i_ron
Quote from: hydrocontrol on June 15, 2009, 02:57:11 PM
I would agree except what is the point when someone with moderator privileges deletes post even if the thread was not started by that moderator. If possible Stephan should set this thread so only he can delete post or maybe Stephan should review Thane's moderator privileges.
I would like to thank all of you for your support and encouragement!
I am pleased to see so many of you can see what just took place here. This is not my cup of tea and I am at a loss as to how to handle this sort of attack.
As one member wrote me, this information about the companies was in the PP Presentation that Thane himself posted. He has sent it to several people including a Star reported so I see no reason for him to delete it... other than my conclusion was too close to the truth for him.
As you may remember, when I started posting my results on the old list he turned against me most visciously and withheld the promised e core material. And he stopped California Power from sending me this material.
So really it came as no surprise this time when he jumped in with both feet and tried to marginalize hoptoad and myself.
It was a mistake for Stefan to leave him with moderator status. Again I remember when a whole block of critical posts went missing from the old list. He lied at that time and said he didn't know how it happened.
So consider the source on this link but he does raise some pertinent points.
http://www.sciscoop.com/perepiteia-explanation.pdf
Also reread deboss and linderman on...
http://peswiki.com/index.php/Talk:Directory:Perepiteia_Generator_by_Potential_Difference_Inc
And reread my analysis of the tri core... you should be more willing to accept the true potential of his invention
Ron
Pageygeeza
I'm still trying to get over it.  Weird how somebody like Thane could do that and be childish about it rather than fess up that he can't allow his work to be repeated.  If he would have done that, then fair doos.  Admittedly, I'm not far off from getting mine completed.  I would really love to post pics, but unfortunately, I've worked too hard on this project for it to be taken over.  It may seem like greed, but I have posted my reasons elsewhere.  I will be looking at getting help from a bigger company to help me achieve my dreams.
I wish everybody luck.  And try not to copy Thanes work too much, you never know, you may be treading into copyright infringement territory.  Going by what I've seen here in the last few days, it's possible.
hydrocontrol
Quote from: i_ron on June 15, 2009, 03:57:41 PM
Ron
They make some interesting points but they are from Feb 2008 which was way before Thane was using a transformer to short the HV coil causing acceleration while at the same time driving a couple of bulbs from just one coil/core. I am not so sure the observations back then apply now. If I were to believe them then what would be the point of a replication thread since they are convinced it is all a H... I mean "Illusion".
i_ron
Quote from: hydrocontrol on June 15, 2009, 04:36:41 PM
This is true... but don't forget that all the readings are done on DMM's.
I found that mine read nearly 30% high at the Hz this is turning.
Ron
