Thane Heins Perepiteia Replications
Started by hartiberlin, May 28, 2009, 05:54:52 PM
minde4000
Quote from: Asymatrix on July 14, 2009, 10:31:15 PM
Surely a man with a 1000% efficiency transformer would immediately realize that he has OU, close the loop, and become a trillionaire.
Wouldn't he?
'waits for post deletion'
How dumb are you?
samedsoft
Dear Asy,
  Please remind that this system (BTT) is not complete enough to be looped.
  BTT converts pure reactive power to pure active power. You need another device like Rotoverter or Transverter to generate excessive reactive power from active power.
  Ash has already given information on this issue.
  I admire Thane's background and his consistency.
  Please try to understand the basics of BTT and then put forward your idea.
  Love & Brothership
  NT,TR
ashtweth_nihilisti
THE WAY TO DEMONSTRATE OU
IS A LOOPED SELF RUN APPLICATION
RUN SHIT OFF IT, NO METERS, NOT NOTHING BUT REAL LIFE MECHANICAL WORK
license it, don't patent it.
BECOME A WORLD FIRST TO SURPASS EVEN TESLA
OR GO ON A WILD RIDE. SIMPLE ;)
feel the vice
Ask Stiffler or .99 to replicate it and show the readings or cranky BUTT
ill replicate this if it works, if it doesn't, watch out. I think it will,
RV test commence this week.
Thane if you want us to know something we don't email us.
This will help creditability, Panacea does NOT screw' around, check you tube,.
ASHTWETH
?If you create your own electricity, heating and water systems, you create your own politics. Maybe that?s what they?re afraid of.? ?? Michael Reynolds
http://www.panacea-bocaf.org
http://www.panaceauniversity.org
http://www.geocities.com/glorybangla/cqtes.htm
baroutologos
@ Mr T
Quote2 COILS BIFILAR SERIES WOUND - SERIES CONNECTED. NON BIFILARS AS ABOVE WORK GREAT IF YOU WANT SERIOUS BRAKING OF THE ROTOR UNDER LOAD.
again you meant Parallel wound-series connected i suppose.. :)
Quote@ 30 OHMS @ 20 GAUGE WIRE 90 LB-ER ROTOR MAGNETS.
question! How much weight your new coils???
question2: So mr Heins, bifilars in that way have better load handling characteristics huh? :) Or put better, They can output MOre for same input mechanical energy ?(This is a crucial matter)
@Minde,
Yes, unfortunately, biffilar coils cannot tolarate too high voltage (as 1800 of your previous one!!) since each adjacent pair of wires has the maximum voltage difference.
To be safe you  must operate coil in 200-400 volts range. Again, this should be according insulation wire coating specs.
Anyway, sad drawbacks are. Make a break, take a hike, cast a curse and continue man!
Baroutologos
CRANKYpants
Quote from: baroutologos on July 15, 2009, 01:50:29 AM
@ Mr T again you meant Parallel wound-series connected i suppose.. :)
JUST CHECKING TO SEE IF YOU ARE ON TOP OF THINGS THERE BART?  ;)
YES - PARALLEL WOUND-SERIES CONNECTED!
(I HAVE A PROBLEM WITH THAT PART OF MY BRAIN I GUESS?)
WEIGHT = 1/2 - 1 LB
Quotequestion2: So mr Heins, bifilars in that way have better load handling characteristics huh? :) Or put better, They can output MOre for same input mechanical energy ?(This is a crucial matter)
I SEEMS THEY CAN PRODUCE THE GREATEST ROTOR ACCELERATION w/ THE MOST OUTPUT POWER.
YOU NEED TO GET THE WIRE GAUGE LOWER IF YOU WANT TO GET POWER.
"SO FIRST YOU GET THE POWER"
"THEN YOU GET THE MONEY"
"THEN YOU GET THE WOMEN"
-Scarface
T
