0 Members and 36 Guests are viewing this topic.
Zeitmaschine
Quote from: xenomorphlabs on September 16, 2012, 06:22:29 AM
A STRONG indicator that TK is not interested in a strong magnetic field in the core was pointed out by me a year ago here :
This would be especially true if all TK coils are there for decoration purposes only. And I'm not sure whether all coils in aquarium 1 are real coils at all or just tubes made of cardboard wrapped with adhesive tape.
T-1000
http://www.liveinternet.ru/users/edward_lee/post235235326/
About fndings of effect:
ЭÑ,,Ñ,,екÑ, был замечен случайно , когда насÑ,раивал Ð".Н.С. в качесÑ,ве оправки для намоÑ,ки коаксиала использовал сÑ,арую мини Теслу.
но на ней была намоÑ,ана еще одна обмоÑ,ка проводом 0,65 и я пыÑ,ался на ней добиÑ,ься Ñ...орошей искры, насÑ,раивал Ð"НС и как Ñ,о подключил к ней емкосÑ,ÑŒ, и получил Ñ...ороший удар Ñ,оком. Совсем не поÑ...ожий на обжигающее прикосновение Ð'Ð' Ð'Ч. ТуÑ, дальше пошли эксперименÑ,Ñ‹ именно в эÑ,ом направлении. Я не преÑ,ендую, чÑ,о моя консÑ,рукция являеÑ,ся самой опÑ,имальной, но самое важное я получил, и буду рабоÑ,аÑ,ÑŒ дальше опÑ,имизируя и изучая данное явление и усÑ,ановку.
Translation:
The effect was found accidentally when I was tuning GNP (generator of nanosecond pulses). As base core I used old mini-Tesla. But on it I winded one more coil with wire diameter 0,65mm and I tried to get good sparks discharge on it and when was tunning GNP I randomly atached capacitor. Then got shocked by current unexpectly. This was not anything like touching high frequency secondary coil of TT. This is where there was more experiments specially in this direction.  I do not pretend about best construction of circuit but I did got most important thing in it and will be working more with device optimisation and learning about current effect and device
http://www.liveinternet.ru/users/edward_lee/post235235706/
Еще одна Ð'АЖНАЯ деÑ,аль- Ð'ЕЗ ХОРОШЕÐ"О ЗАЗЕМЛЕНИЯ - НЕ РАÐ'ОТАЕТ!!!!!!!!!!!!
One additional very important detail - without good grounding - it does not work!!!
http://img0.liveinternet.ru/images/attach/c/6/91/403/91403766_Generator.JPG
http://img1.liveinternet.ru/images/attach/c/6/91/467/91467647_100_6327.JPG
frantz
Hi all,
question: Do you know how look difference between velocities of electrons in electrostatic field and magnetic field? separated of course.
jbignes5:
I think Electrostatic is field responsible for fast moving of electrons. Magnetic field is responsible for moving large amount of electrons but with frequency of changing Magnetic field. Larger amount of current is generated in first moment after appearing od HV electric field (capacitor). In coil we have different situation, we have largest current when voltage falling. Question how to combine these two opposing phenomena together in a single device?
leo48
Quotequestion: Do you know how look difference between velocities of electrons
Although there are many theories, we can not exclude the phenomena known
an electric field attracts or repels electrons instead having a magnetic field it is
possible to deflect one or more electrons only if they are in motion.
Leo48
Every problem has always at least two solutions simply find
The strength of the strong is the ability to navigate struggles with eye serene
jbignes5
Quote from: frantz on September 16, 2012, 02:24:55 PM
Hi all,
jbignes5:
Well I think my way of using Tesla's patent of the motor/generator is such a way. Think about it for a second. We have thin wires around the field core. This is the high voltage component. The thicker wires are on the Rotor and wound on a iron rotor to boot. The thinner wires tend to work best with high voltages and the thicker wires work better with heavy current. Think of it like this: thin wires act like thin hoses. Thicker wires act like thicker hoses. If water is put into the hoses a smaller volume of water flows in the smaller hoses but in the thicker hoses a larger volume of water can move. The speed in the thinner wires is also faster as opposed to the thicker slower moving in the thicker wires. Also the force that comes out of the hoses is very different. The volume of the thinner wire although moving faster hit a target with less force then with the thicker wires volume. The thicker wires volume and subsequent force can be likened to current in this analogy. So the thinner wires current will not be equal to the thicker wires current. But this is as far of the analogy that I will go because it seems that the thinner field coils will still move the thicker wires agitated mass. This agitation can be seen as AC current with the energized voltage from the thinner wires electric field.
I will be trying to make a smaller version of the motor generator to see this effect and show it as a proof of concept.
