0 Members and 221 Guests are viewing this topic.
baroutologos
While playing in the lab, I experimented with an effect similar to cavitation. Assume that you have two capacitors: C1 is a large cap with an arbitrary charge (in my case, 120uF at 60 VDC), and C2 is a small capacitor with no charge (0.05 uF). Discharge C1 into C2. What happens? During the impulse, C1 induces in C2 nearly 200% of the voltage in C1....
Interesting line of thinking. By the way, as i see it, the particular experiment of 2 capacitors does not resemble earth capacity. Actually as i see it, earth and an insulated metal object is one capacity and not 2.
Also, If you put in series two earth grounds and a capacitor, it will resemble almost a dead short to capacitor rather capacitor to capacitor connection. In order the analogy to be true, earth somehow should possessed already a difference of potential that is exploited. (as the large cap has in your experiment)
In any case, i find it very stimulating for anyone to experiment with 2 distant grounds as i have said before. Perhaps things are not as we are accustomed to believe.
@ Concerning the Mishail Kapangen suggestion,
The man simply suggests a resonator, with 2 earth grounds. The many capacities could be for frequency adjustment perhaps. Anyway, ineresting.
iceweller
Quote from: forest on December 20, 2010, 04:45:04 AM
did you saw it ?
  I thought I had attached this schematic after the images, which is the one I was referring to in my earlier post - sorry. BTW that schematic was made by MADSATbg who seems to be on the right track by SR's own words.
  Following are some translated explanations given by SR related to the device:
"The setup uses two effects, only in combination they produce results. The arc has a wide range, some of these frequencies are resonant for the "ferromagnetic", which causes certain processes. But the field is "dead" and the work cannot be done, therefore, the second process is started. The sum of these two processes are used for receiving excess energy from the ferromagnet and in the air, this energy is not taken. Ferromagnet can be represented as a material, where a lot of small magnets that imagine are aimed in different directions and can not create the resulting field. The first process allows them to relax, the second turn, so that all these small magnets create a resulting powerful field. If you just say, it creates a powerful magnet with an opportunity to be controlled. Well, on work of classical physics."
   There are more comments by SR which I am trying to translate better.
forest
Seems related to Richard Willis patent. He found a way to turn on/off neodymium magnet by a bifilar coil around it with a HV spikes. Up to 50kW output.
May be related to what Hubbard and Hendershot found and also to Tesla car.
Just a few cents  ;D
