0 Members and 194 Guests are viewing this topic.
scratchrobot
I was reading interesting stubblefield on keelytech.com and thought maybe this is the effect we look for?
The Motional E-Field, (bottom of document)
http://keelytech.com/stubblefield.html
the_big_m_in_ok
Quote from: DimaWari on May 02, 2011, 12:24:41 AM
Hello Guys! What Do you all think about this?
The first thing that comes to mind is, "Magneto-Hydro-Dynamics".
GOOGLizing the subject in quotes will give you the info.
--Lee
penno64
@Scratch,
I think this is close?
Would the HV pulses be creating these "treated" magnets in say SR's setup?
Penno
FittySense
Quote from: penno64 on May 05, 2011, 04:11:48 PM
@Scratch,
Penno
Hey Penno, this should be right up your alley.
I went back and played with the SR modulator circuit today using a NTE40106B hex inverter and when I raise the supply voltage to 13 volts, the pin 2 output goes to 20 - 22 MHZ which is the NMR of Fe 56.
It didn't matter what I used for a cap and the circuit basically worked like a VCO only the supply pin was the voltage. For the resistor, I used a 20K and I accurately measured the sine output on a 100mhz digital scope and frequency counter.
Since I think anyway, that is well beyond the range of that chip, is this a flaw in the chip what is being exploited? That should be an exact replacement for the russian inverter.
The inverter stage after that is to form the 50-60hz so you have a 21mhz modulated 60hz carrier. That translates into NMR every time.
I'm off to the parts store to buy a proper modulator / mixer and maybe someone can point me at a Colpitts that will run at 21mhz. I seem to recall you doing a bunch of work on the Stiffler CE stuff.
The first thing that needs to get done is the driver circuitry. Everything else is worthless without that part being right.
LtBolo
Quote from: FittySense on May 05, 2011, 05:15:24 PM
...20 - 22 MHZ which is the NMR of Fe 56.
...21mhz modulated 60hz carrier. That translates into NMR every time.
Only in a 0.5 Tesla field. NMR is expressed as frequency per Tesla and is not a fixed frequency.
