Thane Heins BI-TOROID TRANSFORMER
Started by shimondoodkin, July 24, 2009, 11:33:44 PM
wojwrobel
hello
i did a little investigation and came to idea that Heins is using two different coils one on top of the other !!
first coil "shifting coil" has very thin wire and many turns and its shorted and due its its own resistance it creates its own "voltage field" some kind of static charge that affects second coil that is "producing coil" so its behaves like capacitor that stores energy for a while and when magnetic field is leaving the coil the "shifting coil" loses its strength and allows producing coil to discharge the current so it not effecting the magnetic field that is gone ...
and that's how i think he shift current out of phase .....
cheers from poland
wojsciech
ps. this is the patent that have explanation to all what happens in the pickup coil,, CA2437745A1
Bruce_TPU
No, I think it is much simpler than that!
Please watch this video and he shows and tells EXACTLY how he does it.  The idea is very simple!  This shows a COP >300%
Video:
http://www.youtube.com/watch?v=RbRPCt1-WwQ&feature=related[/glow]
Cheers,
Bruce
teslaalset
Quote from: Bruce_TPU on June 06, 2010, 07:53:57 AM
Video:
Cheers,
Bruce
Indeed a good demo.
Disadvantage is that this will only work at low power levels.
The core with the high permeability will already saturate at low current values.
But still a very nice idea to investigate further.
wojwrobel
Bruce
I know every second of his videos VERY WELL ;)
and the reason im posting this information is to streight it out , I HAVE TRIED MANY DAYS!! ;)
thats why im saying its not that easy as it looks !
wojsciech
teslaalset
Quote from: wojwrobel on June 06, 2010, 09:33:17 AM
Bruce
wojsciech
wojwrobel,
What kind of core materials did you use?
Any pictures of your setup?
