Thane Heins BI-TOROID TRANSFORMER
Started by shimondoodkin, July 24, 2009, 11:33:44 PM
CRANKYpants
Hi Guys and Gals,
Test Overview:
Previous IP iterations of the BITT employed a high impedance Primary Coil as deterrent to a Secondary BEFF induced flux. This test data pertains to a low impedance Primary Coil operated at saturation as a deterrent to Secondary Coil BEMF induced flux.
Test Conclusions:
Primary Coil Power Factor Reduction
Saturation of the Primary Coil’s core reduced the Power Factor by 11.1% from a NO LAOD PF of 0.17 to ON LOAD PF of 0.0.
Primary Coil Input Current Reduction
While the Load Output Voltage increased by a factor of 9400%, the Primary Coil Input Current reduced by 1.34% or 10mA.
Cheers
T
btw:
You can't uses one magnetic field to cancel "out" opposing fluxes - since they pass each other like "ships in the night."
CRANKYpants
While the Load Output Voltage increased by a factor of 9400%, the Primary Coil Input Current reduced by 1.34% or 10mA - an interesting anomaly which was identified previously a couple of years ago with GOTOLUC and I and in early BITT as shown here at Ottawa University:
http://www.youtube.com/watch?v=WP7zmk1t2gI
Also of note:
The ON LOAD PF also improves from NO LAOD to ON LOAD as seen below...
CRANKYpants
AS YOU CAN SEE WITH A SATURATED PRIMARY - THE POWER FACTOR OF THE PRIMARY IS REDUCED TO 0.0 (PURELY REACTIVE) WHILE THE SECONDARY COILS DELIVER (REAL) POWER TO THE LOAD.
EFFICIENCY = INFINITY
THIS IS THE SAME RESULT DR. FUSINA OF THE DEFENCE RESEARCH AND DEVELOPMENT CANADA DISCOVERED WHEN HE TESTED THE "OLDER" BITT ABOUT A YEAR AGO.
TO REQUEST DRDC DATA: send and email to thane_heins@yahoo.ca  8)
CHEERS
T
ABOVE PHOTOS:
High Voltage Sine Waves w/ Core Saturation Power Factor = 0.0 @ 90 degrees.
BELOW PHOTOS:
Low Voltage Sine Waves Power Factor = 0.17 @ 80 degrees.
CRANKYpants
AN INTERESTING EVALUATION FROM RUSSIA ON THE REGENERATIVE ACCELERATION GENERATOR (RM) SHOW HERE: http://www.youtube.com/user/ThaneCHeins
Russian Academy of Science
"I’m very interested in what you are doing with your experiments, because from the mathematical point of view what’s going on in your experiments is the break of SO3 symmetry in fundamental tensor of Yang Mills equations that makes it obvious to see the flaws if Maxwell electrodynamics."
"Thank you very much for the detailed answers you provided! Number of your experiments (Multi Coil Stators and bi-toroid transformer) are not lying in the field fo Maxwellian electrodynamics. Today I made a numerical simulation of a model problem â€" simulation of the Ampere’s force on the coil from the moving permanent magnet using Maxwell set of equations with bias currents in conductors. I changed number of terns in the "coil" and varied magnetic and electric properties of coil material to get the equivalent of high R and Z. In the simulation there are no effects that you have in experiments â€" in the simulation there’s a direct Lenz law as its stated by the physics. That is fascinating!"
Yours truly,
Nick.
Dr. Evstigneev N.M., leading sc., dep. of chaotic dynamics,
Institute for System analysis,
Russian Academy of Science.
teslaalset
@Crankypants
Did you make these photo's yourself?
It not clear from your posting whether the info you used are from Thanes or your own setup (if any).
Can you please elaborate a bit more?
