New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
0 Members and 84 Guests are viewing this topic.
winsonali
please do not get offended by all means i didn't mean to hurt anyone
i have discussed every thing very openly and have also mentioned where i am stuck, i have to finish the working by myself. well scams, measurement errors , tricking the meter , wrong theories , they all have one simple answer a complete product.
robbie47
@ Ali,
If you need help from an experienced electronics engineer but want to take it offline, just PM me.
winsonali
reply: robbie47
the LC circuit is one of the method to generating frequency, the other way is digital oscillator i have develop a digital circuit with feed back control you can see multiple capacitors in circuit this is where we are storing charges as a water tub and through siphon the level is raised to new voltage levels remember destination is going to be a lower level then initial start up otherwise it won't work
in our test i will not use watt meter the video was to show a lay man that less energy is consumed
for technical peoples measurements and numbers are good enough to establish results.
regards
Ali
robbie47
Thanks Ali, that makes it a bit more clear.
Is the output frequency 50Hz with sinus wave shape or square wave shape?
hartiberlin
Hi Ali,
sounds like you use the principle to load 2 caps in parallel and then switch
them in series, so you double the voltage, more like voltage doubler circuit.
Normally current just halves, so the power stays the same, but maybe you invented
some kind of strange MOSFET controlled switching frequency, that raises
the switching frequency
with some kind of feedback loop, so more charges in the caps are transfered to the
higher voltage potential ?
But what when you run out of electrons from the bigger first cap ?
I still don´t understand the Siphon effect.
Your example with the bathtub sounds logical, but does not make much sense
to me, cause in this case you might get only a potential energy difference for maybe
50 cm when you draw the water over the top
instead of in the bottom of the bath tube.
But if you would make a Siphon like using a hose and put the hose from under the bathtube
water surface first 3 Meters higher and then going from there
lower than the lower bathtube exit hole, you will definately draw first the water 3 Meter higher
and then the water goes over the top in the 3 meter higher hose and then will flow
down the rest of the hose to the output of the hose, which is lower than the upper
water level.
Now if you have found a trick how to trap some of the water there at 3 Meter higher level
and build there a storage before it is going down and keep sucking up more water higher
than goes down at the other side and thus get more and more water to the 3 Meters top,
this would be interesting.
So now the question is, how do you do this Siphon effect electronically with Electrons.
As it is your secret you will probably not tell us yet.
Well, maybe the best solution would be to design it this way, that you
really use a 12 Volts or 3 x 12 Volts battery in series= 36 Volts DC input  power
source, so you can show it with a better measurement DC power input.
P.S: Did you also try it with a 220 Volts to 30 Volts AC transformer as the input
or just only with the TRIAC dimmer circuit ?
I hope this is not related to the Meter-Triac jamming as
EMdevices has suggested, so better just try it without this
meter and without the TRIAC dimmer circuit by just using
a 220Volts to 30 Volts AC transformer for the input and
measure then using a scope with a shunt for power input.
