New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
winsonali
previously we were using the standard DC formulas
these meters are true RMS and show exact power consumed over a complete cycle
the input device getting peak 5.0 amps for only micro seconds and only for 49 volts rms and voltage and current are in same phase if we distribute the power for over all cycle it will give you real power(meter showing)  on each cycle so these readings are correct
i want to post oscilloscope wave forms but that will take more time for explaining
the end result is
where i have installed 2 units we are consuming less electricity bills the device can be used as transformer less, coil less or solid state voltage stablizer with energy saving feature
countries where we have power fluctuations this is low cost and energy saving device can be used with aircons and reduce electricity bills
yes one thing more this time we have switched the input and output such that when device is taking input the output  is in transactional phase (shifting from negative to positive or positive to negative more or less on zero) so when input is coming,  there is no out flow when output  flow is through (we block the input section) no input is coming so it looks  like it collect a bucket of charge,  close the input door,  process it through output and return to input again.  We are not taking any  input when output is open for flow.
i am still working and have targets to achieve.
a very interesting thing i put a "coil with permanent magnet in side" before input without changing any thing  and the power was so high that every thing blow up in blink of an eye
on investigation the positive side of output was blown and same as input was damaged where positive input is seperated after zero detection
but when i just flip the coil connection and magnet inside it this time negative side blow up
i need to work a lot now
Ali
teslaalset
Quote from: winsonali on November 03, 2009, 09:24:56 AM
yes one thing more this time we have switched the input and out put such that when device is taking input the out is in transactional phase so when input is coming there is no out flow when out flow is through no input is coming so it looks  like it gets a bucket of charge close the input door process it through output and and return to input again but it never take the input when output is open for flow
Thanks for some more information, Ali.
Would it be possible for you to explain the above via a diagram or a drawing?
It is very confusing only reading your text.
spoondini
I worked out the same math as homersimpson.  Ali - are 'we' missing something?
Well,
I think it is not good to use any digital meters over here,
cause they are probably just made for normal sine waves and
not for chopped dimmer outputs.
well at least Icould imagine, that the current readings
also takes samples from the momentary highest values,
but the power reading calculates into the cos phi phase angle and
thus shows less power input.
It would be required to show us scope shots of the input current and input voltage
with dimensions and also show the output voltage as an additional scope shot.
Then we could say, what is really going on in this circuit...
Otherwise I will never trust digital meters in these pulse circuits.
Well, I hope that it is not just jamming ALI´s home metering system and
thus save him the electrical bill.
It would be good, if Ali could post some scope shots.
Many thanks in advance.
Regards, Stefan.
winsonali
surely i will record the screen shots from oscilloscope and will post in my new video
