New invention of motion less generation of electric power
Started by powercat, August 26, 2009, 08:52:05 AM
Nihilanth
Quote from: gravityblock on November 23, 2009, 05:50:03 PMIn this video http://www.youtube.com/watch?v=V-dbGUcnFaI&feature=channel , you can see the magnetic monopoles when the lines of flux are disconnected from each other.
Those aren't monopoles.
Quote from: winsonali on November 23, 2009, 08:43:16 PMwhen a radio starts transmission at 5 watt its power doesn't change no matter how many receiver starts receiving the signal.
One could use a single tuning fork to resonate with multiple other tuning forks, getting the same output for however many tuning forks there are. A bunch of PZT tuning forks would be a rather noisy overunity device. :P
"I think it's better to have ideas [than beliefs.] You can change an idea. Changing a belief is trickier. Life should malleable and progressive; working from idea to idea permits that. Beliefs anchor you to certain points and limit growth; new ideas can't generate. Life becomes stagnant." - Rufus the 13 Apostle.
teslaalset
for this purpose EE must be released from its active zone to passive zone where it can move freely and then recaptured in active zones on multiple channels this will give us extra power generation then input
Hi Ali, can you explain what you mean with 'release from its active zone to passive zone'?
Maybe you can give an example?
Thanks!
forest
for me it means - let it oscillate freely and take an effect on surrounding ambient in unconnected (to source ) receiver
gravityblock
Quote from: Nihilanth on November 24, 2009, 03:18:36 AM
They are magnetic fields.  You can clearly see the monopoles carrying the magnetic fields when they are reconnecting to each other.  Just watch the two ends of the disconnected field lines connecting to each other, which connects the poles to form a dipole.
A dipole field is made up of two poles.  A monopole field is made up of 1 pole.  Where the field lines connect there is a zero point.  The monopoles being this zero point and connecting the two fields together.  I can show you a video of energy coming out of this zero point if you like.  The energy that is released are the magnetic charges and are not electrical charges.
Monopoles can be viewed as magnetic charges which carries the magnetic fields and connects the poles together forming a dipole field.
Please send me a PM if you want to discuss this.  I don't want to distract from the topic of this thread.
GB
jan.kolar
Ali, Ali you have not heard about law of energy conservation? Yes you can have 100s of receivers but signals on input antennas are very small typically microvolts. Also there is feedback between receiver and transmitter similar to coupling between secondary and primary side of transformer (Lenz law).
Regarding the so called magnetic monopoles i dont believe these are true monopoles. According to wikipedia article div B = 0 so classical theory is valid. Its similar to monopole in appearance but thats all not saying that this discovery was not confirmed by independent researchers. Popular press trying to attract readers.
