Bedini SSG - self sustaining
Started by plengo, August 28, 2009, 08:04:34 PM
Magluvin
I will do a vid soon. I am ordering some higher voltage caps to better handle the output from the oscillator. The 2 100v on each leg of the oscillator output I believe are leaking the full potential of what I can get to the bridge and the storage caps. This was something I had an idea for a while back and just whipped it up the other day.  The idea came from a thought of necessity of shorter pulses to a coil than I was getting from rotor motion alone, to get more efficient bemf compared to power consumed during the reed on cycle from the rotor speed.
The freq seems quite high when adjusted properly, above 8khz with these reeds.
Will do a vid soon. Been so busy, I was lucky to have time the other day to mess with it a bit.
Mags
Magluvin
Plengo
What happening?  Did you get the coils in yet?
Im still waiting for caps. The setup that self oscillates to run the motor circuit is kind of inefficient. But man the rotor runs. Ill do a vid here soon. Havnt played for a bit. The caps I need are for the ones that the bemf from the oscillator, in series, to the rect/charge caps. Its putting out up to 400v and the caps I have are 100v and I dont want to kill them. They may be leaking and consuming what Im making.
All this playing, I dont know if we will get more than in unless we figure some good tricks to this. I think bedini has the answers, but is only giving us a taste and we have to figure out the rest, just like everything else.
Thats why Im delving into Tesla stuff to see what I can figure out. It would be nice to really harness some free juice. Even just a little.
Mags
plengo
I agree about Bedini. Only bits and pieces and that after many DVDs. :)
Well my 3 bedini board cooked and I get pissed and started designing a new board again. SSGs dont work well all in one board because of its RF component. They all bleed to each other.
I did get some interesting effects using the big toroid and SSGs. High voltages with very low input voltages. This big toroid did not work just pulsating with my controllers like Bob Boyce say, but I did not have his controller either, so it still needs more testing.
Definitely I will play more with it. So many things to do and experiment so many failures and so little successes.
Fausto.
Magluvin
Just a tidbit, in my self oscillator setup, I have a lead off of each end of the coil going to the 2 series caps that go to a bridge rectifier. With the motor pulling from the charge cap far end of the bridge, the osc. reed is heard nice and clear, no visible spark at all. If I remove the load (motor), the charge cap goes all the way up and the osc. reed gets quiet(no sound) and a blue glow surrounds that contact tips. Is it possible that the reed contacts are not even touching at this point and the conduction is just crossing the plasma glow? I will show this in the vid also. It just seems strange like it is oscillating without reed action at this point.  Also, do you know if it might be producing any harmful radiation in that glow? =0
Mags
Magluvin
