COAX TPU...
Started by innovation_station, September 05, 2009, 10:05:51 PM
giantkiller
Requirements:
Resonance frequency of your coil.
a 2 pulse system by using two frequencies.
Each pulse 5 to 50 ns.
Synch both pulses dead on then move the 2nd pulse outward or away with a delay.
You will see a single pulse, then a saddle pulse, then the second hump of the saddle will increase above the source voltage.
Depending on the turns, mass of copper, the diameter then your Kick should be present and quite high. This is why steel and iron don't work. Copper is faster and drops the field quicker. The  echo hits our conductors.
If you haven't done this you haven't seen the kick. This has not been stated in what I have seen. If I have missed a thread with these exact instructions then post it. Otherwise nobody here has seen this Kick.
I have done this and have seen the kick. It is a reverberation from Nature, an echo. You will have no current consumption based upon power usage.
--giantkiller. I stand on the shoulders of those before me.
innovation_station
i have not done this test ...  however all materials to do so have been delivered ...
gk ...  i can understand what is going on the doors are slamming shutt... the returning echo
is the kick you are feeling  this is not for the unexperienced..   baby steps ...
ist!
szaxx
Hi all,
Not totally up to speed on this thread but the info given is to allow a very fast pulse output from a somewhat slower one.
Free patents online, find Patent US4707619 to view what I am talking of. The ones you were speaking of are not too well known. Unless the pincushion correction cores are of use, someone knew of TV engineering it appears before the first TPU was made.....some patents of these are at the same site also.
cheers Steve.
Gobaga
Quote from: BEP on November 30, 2009, 01:39:21 PM
Sorry.
Never found a patent for a toroidal saturable reactor with the poloidal windings reversed half way around like the ones on some of the TPUs. On top of that, the cores shown don't even look like cores. They look more like a coil form. So you need to guess what is inside connected to the other two wires.
I've seen thousands of toroidal cores in my lifetime. None look like the one in the TPU.
BEP
Steven's toroid looks like a toroidal isolation transformer wound for high voltage.  Single winding to keep the high potential end from the low potential end and looks like a high voltage isolator in the middle.  That flushes the saturable reactor idea down the crapper.  Ol' Steve would have used this to isolate the pulse coils from the signal source.  Can't have  freaky stuff screwing up the timing.  See attached:
Gobaga
Quote from: giantkiller on November 30, 2009, 01:59:15 PM
Requirements:
This was discussed here and appears to be pulse compression:
http://www.overunity.com/index.php?topic=7377.msg188871#msg188871
Sweet thing about this is no hv switch is required.
In order for this to "do something", there has to be something to "do something" to.
