COAX TPU...
Started by innovation_station, September 05, 2009, 10:05:51 PM
techieatwork
I want to build one too.
Pls tell me the schematics, and I will start asap.
I thought a bike rim pure aluminum would be a good core for a coil, then, if needed, I can wrap with black-sand (soft iron, no eddy currents) core around it.
Pls tell me what next.
techieatwork
tsl
blind building will not do it. also it would be wise to consider that the width of the pulses generated by a coax are damn short and also adjustment would be a pain in the ass.by using a coil as the shield of the coax you'll have more controll over the named parameters
still, i'm glad to see that my idea is rooting.
take care,
tsl
szaxx
hi all,
If the pulses you need are to be veery short you can always use the best pulse genny you got and send the pulses into a saturable inductor. Simply a toroid with a few turns around it like the same as S Marks has in his device. what happens is the pulse current builds a magnetic field in the ring and this shortens the pulse out by becoming saturated. do a search on them there are some very good patents on these giving info on building. as a bonus to pulse  shortening if you build them correctly they act as a magnetic amplifier and all the power you put in comes out in a much greater amperage with corresponding shorter pulse.
hope this info is useful    steve
innovation_station
yes well i have well over a few thousand feet of coax ..
i was given 2 15db 15vdc rf amps.. and some HUGE SURGE PORTECTORS..
a few ways i would hook up such a unit ..
otto way ...  all 1 wire ...  copper center .. is the loop alum caseing is otto collect ..  colpase will collect on alum and be added to center copper .. or you just center copper ... and colide in the ring ..
alum should contain it to a degree..
have fun ..  shop is almost finally set up ..
ist! i have truck loads of bigtime rf gear ... you dont just walk into a store and buy what i have aquired ... lol   you need a liecence to purchise .. this gear ..  ;)  the amps i have are not small !
i have almost a compleate cable system .. just taken down from use 3 or 4 months ago.. including 3 fibre nodes..
BEP
Quote from: szaxx on November 30, 2009, 08:05:22 AM
hi all,
Sorry.
Never found a patent for a toroidal saturable reactor with the poloidal windings reversed half way around like the ones on some of the TPUs. On top of that, the cores shown don't even look like cores. They look more like a coil form. So you need to guess what is inside connected to the other two wires.
I've seen thousands of toroidal cores in my lifetime. None look like the one in the TPU.
BEP
