exploiting equilibrium
Started by mr_bojangles, September 10, 2009, 11:49:50 PM
mr_bojangles
well here it goes
my idea stemmed from the magnetic disk rolling down an incline, lined with stators inducing electricity
i wanted a way to "perpetually" keep it rolling down the incline without having to deal with lenz law (but aren't we all)
anyway, the idea is having the incline being a larger distance away from the fulcrum. the mass above the fulcrum (magnet disk, incline material, stators [possibly not]) is equal to the counterweight, but the counterweight being twice as close to the fulcrum
ok so we have a system that is perfectly balanced, so it takes minimal effort to make it oscillate
now with this in mind, if we moved the counterweight x amount of inches, it makes the center of the incline move 2x, meaning we can make the magnetic disc induce electricity and lenz law is interpreted into the disc fighting angular momentum and not affecting the amount of energy to make the system oscillate
theoretically we could have multiple sets of magnetic discs as the counterweight would just need be adjusted
in addition we could also theoretically increase the distance between the incline and the fulcrum, making the movement exponentially larger
here's a couple drawings, let me know what you think
"If at first you don't succeed, try, try again. Then quit. There's no point in being a damn fool about it."
-WC Fields
onthecuttingedge2005
Hi Mr bojangles.
I demonstrated in a video in the past how to steer a balance point to allow a weighted object to rotate down hill towards the pivot.
I use no other force to get it going other than steering the path for the pivot point throwing it off center constantly, the weight does the rest.
I am not even fighting the counter weight if I keep it timed right. very little effort is being applied.
http://www.youtube.com/watch?v=3TM1hxvkf9A
Jerry
mr_bojangles
put a magnet on the end and let it spin in front of a stator
create a mechanical set up and try using a weight so you know exactly how much force it takes
what applications do you see for that
-WC Fields
mr_bojangles
can anyone tell me why this wouldnt work?
the only thing i can see is that the magnet wouldnt induce enough electricity, but the distance of the incline can be increased to infinity
plus the system is balanced throughout the whole process
it seems with a specific amount of mass and strength of the magnet this would work
anything?
-WC Fields
spoondini
Interesting.  I think the lever won't actually magnify amount of work performed.  Stators will create drag on the magnet and require more vigorous  work to be performed on lever.  That being said, it just might work.  I'm really digging many of the ideas combining mechanical, gravitational, and magnetic properties.
