Romanian SECRET Technology which WORKED ! Lots of OU.
Started by spacetrax, September 20, 2009, 05:11:09 AM
EMdevices
Asadar,din start toate problemele pe care le ridica astia de pe internet sunt niste ineptii...Componenta rotorica nu trebuie sa contina pe ea (electro)magneti iar dinamica masinii rotative nu trebuie sa aiba la baza sa INTERACTIUNEA dintre doua sau mai multe surse de camp magnetic,ci reactia unor elemente susceptibile magnetic fata de campul magnetic creat de surse statice,fixe.Faceti daca va place o similitudine cu turbina hidraulica sau eoliana,care este un element reactiv introdus in "liniiile de forta" ale curentului fluidic ,- turbina va transforma energia potentiala a fluidului in energie cinetica a elementului rotativ ; ar fi mai eficient daca asupra axului rotoric ar interactiona tangential un numar mare de jeturi fluidice ?! Evident ca nu ! Axul rotoric abia de s-ar putea misca iar cheltuiala de energie fluidica ar fi uriasa...Cam asta este cazul actualelor motoare electrice...,-pachete masive de miez magnetic si bobinaj pe stator si rotor,care cu mari cheltuieli de curent electric se caznesc sa interactioneze cinetic,dar cu mari pierderi datorate histerezei,curentilor Foucault,retardului de demagnetizare si fortelor contraelectromotoare care apar intre stator si rotor,momentelor de inertie de care sufera greoiul rotor clasic,etc,etc,etc...
Therefore, from the onset, all the problems raised by the folks on the internet are nothing but absurdities…  The rotational component should not contain on it any electromagnets, and the dynamics of the rotational machine should not be based on the INTERACTION between two or more sources of magnetic field, but on the reaction of magnetically susceptible elements against the magnetic field created by static sources, which are fixed.  If you like, make a comparison to a turbine for hydraulics or air flows, which is a reactive element inserted in the “lines of force” belonging to the flowing fluids â€" the turbine will transform the potential energy of the fluid into the kinetic energy of the rotational element; will it be more efficient if a number of forces, from fluid jets, will interact tangentially upon the rotational axle? Evidently not! The rotational axle will barely move, and the expenditure of fluid energy would be gigantic… This is roughly the case for the current electric motor: huge chunks of magnetic core and coil wire, on the stator and rotor, which with a large expenditure of electric current, is struggling to interact kinetically, but with large losses due to hysteresis, Foucault currents (eddy currents), retardation due to demagnetization and forces opposing the electomotor which appear between the stator and rotor, and the rotational inertia plaguing the bulky classical rotor, etc, etc, etc…
Andreic este uimit de ce solutiile obtinute in cadrul activitatii secrete de cercetare nu sunt aplicate...
Exista un joc al intereselor aici.Din fericire(...)Romania contemporana este confruntata cu grave probleme economice iar acestea reclama solutii imediate si de mare eficienta,care totodata sa fie si ieftine,accesibile dpdv tehnologic,etc.
Am zis ,,din fericire",pentru ca de n-ar fi fost starea actuala de criza,nici nu s-ar fi pus in discutie scoaterea ,,de la naftalina" a acestor vechi inventii(unele din ele au deja respectabila varsta de...40-45 de ani !) care atata vreme au fost strict secretizate ; daca astazi pot sa mai dau drumul la gura este tocmai pentru ca s-a pus in mod serios problema utilizarii acestor inventii ; probabil ca la inceput aplicatiile vor fi restranse,in domeniul tehnicii militare sau aplicatii civile dar pentru categorii restranse de beneficiari,gen Presedintie,Senat,etc ,- dar indiferent daca la inceput aplicatiile se vor face intr-un cerc foarte restrans,va fi totusi un mare pas inainte ! De 35-40-45 de ani, inventiile din cadrul anumitor dosare de cercetare au fost adanc ingropate si numai cativa oameni dintr-o tara intreaga au avut acces direct la astfel de informatii.
Sper ca foarte curand, regimul juridic al acestor informatii sa sufere o modificare importanta, caci atunci voi putea in sfarsit iesi public fara nicio retinere - la TV,in presa,pe internet,etc.
Forum user, ANDREIC, is amazed at why the solutions obtained, as part of the secret research activities, are not put in practice.  Unfortunately, there is a game of interests here.  Present day Romania is confronted with major economic problems and these necessitate immediate solutions, and of high efficiency, which at the same time should be inexpensive, and accessible from a technological point of view, etc.  I said “unfortunately” because if the current state of crisis would not have existed, no discussion would have even occurred about the bringing out, “from storage” of these old inventions (some of them already having attained the respectable age of 40-45 years!) which for such a long time having been kept secret; the reason that today I still dare to open my mouth, is because the issue of utilizing these inventions was seriously brought forth (in high level meetings)  Perhaps, in the beginning the implementations will be limited, for example to military applications, or to civilian applications, but for small groups of beneficiaries, the likes of, the Presidency, the Senate, etc...(i.e. for important individuals) â€" even if the initial group size is small, it will however be a huge step forward !  For 35-40-45 years, the inventions, pertaining to these previously mentioned research files, have been buried deeply, and only a few people out of a whole country had direct access to such information.  I’m hoping that very soon, the laws governing this type of information will soon receive an important modification, because then I will be able to at last come out publicly without any restraint â€" to the media, to the press, on the internet, etc..
to be continued .....
P.S.  As an aside, I wonder if these revealed principles are similar to this drawing. I was toying with these concepts about a decade ago.  Magnetic lines of force will be normal to the surface so if the surface is normal to the radial everywhere on the inside radius no tangential forces result, but on the outer edge we can see the inclination so there will be a net tangential vector force that will rotate the rotor.  I believe others have tried these concepts as well but with no results.  We'll have to see.
mikestocks2006
Hi EMdevices,
Very interesting work.
Thanks for taking the time and effort to provide the translations
Mike
VenomTT
If Gilldarida is Lucian Cozma there is a forum with him on:
http://forum.drumulinvingatorilor.ro/index.php?topic=138.105
And he is talking about Mr. Moraru.
Just my 2 cents. I don't understand anything,
Regards.
onthecuttingedge2005
you can't split an electron in half to make 2, you can't get over unity by the electron alone! you need to use the photon in conjunction with the electron to get OU. please read about Stimulated Emissions.
Jerry :)
