Tesla IMPEDANCE PHENOMENA - FIG 183C
Started by darkspeed, October 05, 2009, 03:42:12 AM
Grumpy
Quote from: darkspeed on October 05, 2009, 01:02:33 PM
Yes , two IB22's and a 1nf Faradon
I think I may be getting some degree of rectification through the difference in resistance.. needs testing..
use a pencil lead (graphite) on one side and you have a point-plane gap - not quite a diode, but assymetrical.
        -Frank Edwards
Grumpy
Tesla mentions that the "magician" circuit was demonstrated in a lecture in April 1895.  I found a copy of it here:
http://www.nuenergy.org/pdf/Apr1895.pdf
        -Frank Edwards
dankie
Little Baby Grumpy , leave Darkspeed alone , he has work to do and cannot hold your hand .
Nice tools Darkspeed .
Grumpy
Quote from: dankie on October 05, 2009, 02:20:12 PM
I showed stuff like this a couple of years ago.  You would have seen it if you were not sucking the hind tit!  HHO wanna-B
You know you are not in Kansas anymore when stuff start moving across the bench...or blows up.
        -Frank Edwards
darkspeed
Quote from: Grumpy on October 05, 2009, 12:45:38 PM
With th gap off-center - how is the spark different?
Have you tried balanced gaps?
I did try balanced gaps to start with but I did not have enough gap so I inserted a very short rod in one side to get more space.
With the balanced gaps the sparks were thin, blue, and if wider produced a rising yellow arc.
With unbalanced through carbon, sparks are much thicker , whiter, and you can feel it if you walk by it.
