Tesla IMPEDANCE PHENOMENA - FIG 183C
Started by darkspeed, October 05, 2009, 03:42:12 AM
darkspeed
Quote from: Grumpy on October 05, 2009, 08:39:12 AM
Why the copper straps?  Looks like they make a "box".
Lay a 4ft flourescent bulb in there if you have one.
Notice the copper tubing - large surface area - uninsulated.
Lots of bad stuff coming out of the gap - don't look at it - I lay safetly sunglasses over mine when it is that bright.
Any difference which side of center the gap is placed?
No diodes?  AC?
EDIT:  I wonder what Tesla meant by the term "conversion"...
Your FIG 2 is the Erick D setup...
Everyone missed the fact the gap is in plane with the device.. and not strung off somewhere in front with wires...
Grumpy
Quote from: darkspeed on October 05, 2009, 12:32:40 PM
The copper straps slide up and down to tune the load.
What looks like a mirror is actually a gold coated welding shield insert.
There is quite a large electromagnet that sits over the gap and holds the viewer insert.. not shown..
Here is the full bridge diode I use when i need it 7.5k @ 1a but seems to work fine with the 15k NTS
With the carbon rods and the gap way off center, the spark is different...
What is that coil in the background, connected to bulbs (LEDs?)?
I have a bridge of 8 (2 in series per leg) NTE517's mounted to UHMW plate - working at 24 ma, 10kv from an ignition transformer.
With th gap off-center - how is the spark different?
Have you tried balanced gaps?
Check for nodes/antinodes perpedicular to the working circuit with a fluorescent tube.
        -Frank Edwards
Grumpy
Quote from: darkspeed on October 05, 2009, 12:42:22 PM
Are you referring to the Dollard video?  Yes, missed this detail.  The cover of his book on the Tesla Transformer has them next to the primary of his magnifier, but the coils are rotated horizontally, so that gap is perpendicular to the coils.
        -Frank Edwards
darkspeed
Quote from: Grumpy on October 05, 2009, 12:57:31 PM
Yes , two IB22's and a 1nf Faradon
I think I may be getting some degree of rectification through the difference in resistance.. needs testing..
Grumpy
Just watched the vid and spark gap tubes are angled and below the coils.
        -Frank Edwards
