Tesla IMPEDANCE PHENOMENA - FIG 183C
Started by darkspeed, October 05, 2009, 03:42:12 AM
darkspeed
Grumpy
Why the copper straps?  Looks like they make a "box".
Lay a 4ft flourescent bulb in there if you have one.
Notice the copper tubing - large surface area - uninsulated.
Lots of bad stuff coming out of the gap - don't look at it - I lay safetly sunglasses over mine when it is that bright.
Any difference which side of center the gap is placed?
No diodes?  AC?
EDIT:  I wonder what Tesla meant by the term "conversion"...
        -Frank Edwards
the_big_m_in_ok
Grumpy said:
Tesla has a "condenser"(capacitor) in his drawings.  But without at least one diode on a rail, he wouldn't get DC.  "D" are spark gaps.  "G" is probably the load.  They're in the correct place to be the load in the drawings.
Is he *converting* AC somehow with the capacitor?  The patent should be read for more details.
Re-edit:
Here's the patent...
http://www.google.com/patents?id=66VeAAAAEBAJ&printsec=abstract&zoom=4#v=onepage&q=&f=false
Between Lines 89-95 of the second column, Tesla is converting the electrical impulses from a high tension and small volume, to a low tension and large volume.
I would only assume he was trying to use the invention as a coil-less transformer?
--Lee
darkspeed
Quote from: Grumpy on October 05, 2009, 08:39:12 AM
No diodes?  AC?
The copper straps slide up and down to tune the load.
What looks like a mirror is actually a gold coated welding shield insert.
There is quite a large electromagnet that sits over the gap and holds the viewer insert.. not shown..
Here is the full bridge diode I use when i need it 7.5k @ 1a but seems to work fine with the 15k NTS
With the carbon rods and the gap way off center, the spark is different...
Grumpy
Oops.   Wrong circuit.
What Darkspeed shows is more similar to this "Magician circuit" to produce damped pulses:
Counsel
Did you find that that was the best condition for transmitting energy without the use of wire?
Tesla
No, I did not use that method when I was transmitting energy.  I used it only in the production of those freaks for which I have been called a magician.  If I had used merely undamped waves, I would have been an ordinary electrician like everybody else.
        -Frank Edwards
