Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
giantkiller
I thought I would leave this previous text in place.
I found the slow leak / charge. I could not find it before. It is a ground loop. I disconnected everything and found a connection from the ground of the Controller board to the ground of the desk scope. The loop consists of the meter to the bridge to the coil to the fet driver board to the controller to the scope ground. The connect from the coil to the fet board is a positive connection. So before as I disconnected items the cap across the bridge output kept the meter reading stable. I have been duped by an allusive connection.
Many apologies are in order. Too many tests going at once on the bench. But honesty is better than prestidigitation.
I can continue on with the next tests more aware now of hidden enemies that lurk just under vision.
Quote from: giantkiller on April 29, 2010, 06:40:59 PM
Yes. I was refering to wife. The 4" set of coils are working models of 18" diameter version. The 18" models were too visible as in big is bad. You get the picture?: Big coils, boxes crashing, wall outlets vibrating...
She saw the big coils and blamed them without knowing. I removed them. Now I know why mad scientists live alone. The political shuffling is killing me. Anyway...
And yes I only have 3 fet driver boards hooked up. Dead! I tell ya! No battery connections and no instrument connections or grounds. I have been disconnecting everything to find the source. Probably just a big antenna. I place my isolated VOM on the bridge output momentarily just to see the 125vdc. If I leave the meter on it settles to 33vdc. So: meter off circuit the coil pops LEDS / meter on circuit the LED momentarily flashes bright and the voltage drops, remove LED the voltage moves back to 33vdc. Put the LED back on the 'Meter on circuit' and the LED momentarily flashes bright and the voltage drops. Like an ambient Joule thief. It is a rats nest of jumper leads.
I will youtube it and show the mess but will clarify the 'no connections' visually. Bolt told me 2-1/2 years ago to get on batteries. I have been off the grid in my experiments ever since. I even bought an isolated OWON portable scope/vom.
Why me, Lord? I just want a TPU! It is just a small request but I have to go to both ends of the universe and learn everything in the middle? Agh!
This is not a trick or fanfare play. I don't have time for games. This is just a byproduct of something else I was pursuing. As Alexander Graham Bell exclaimed "x*-34fgr!" when he got burnt by acid as he was trying to invent the telephone. Go figure. When the LED popped I exclaimed 'Ah, damn!' Then I researched the problem out to find it was something needed all along. Guess I'll go down in the history books as a famous inventor too. ;D
wattsup
@GK
Would not be the first time that has happenned to me. I have to move my voltage meter away from the pulse lines because it can catch the pulse and send it directly into my cap tank. So very delicate effects have to even be cancelled to make sure what you are seeing is in fact what is being produced in the intended manner. lol
Regarding the last two coils you made and shown above, let me just understand.
The right coil in your above photo is a three iron 3 turn ring each wound over in one wind of 360 degrees, each then stacked all covered with a fourth wind over of 360 degrees. A GK331. I would not put the rings in mobius since there is no where for it to go. I would pulse the three outer ring coils and collect on the rings in parallel. I would pulse positive at the same side of three parallel coils but invert the 2nd one. Then I would put a tap on the fourth outer coil center point giving the outer coil three connection points to which each of the inner three coils other ends will go. The second coil should go to the outer coil center tap. The first and third ends could go either way.
The left coil in your photo is a one iron 3 turns ring wound over with 180 degrees, from 0-180 to the ring relation, then over coiled with four halfer lengths, all wound the same way, all sharing the same blotch center that would be in this case 90 degrees to the ring relation. A GK135, Need I say more on that one. Can't wait to play with one of those too.
Now to figure how to drive it with one frequency. That's gonna be fun. So, many ways, I agree.
On my end I wanted to post a photo of my last build before I do the biasing rings. At 7.08mhz, drawing 14.4 micro amps on one wire pulsed, lights up the 5 volts leds and load the dioded cap to 5.87vdc steady. When the led is removed the voltage rises to 50 volts or around. So this coiling is doing the same thing as the toroid was doing.
In this build two individual rings start at the top, go in opposing directions, come back and go down to the bottom ring in the same direction as they left the top ring, makes one turn each and comes out where they are connected together, so the output is the top two ring wires. The pulsed CCs are in bucking mode, in series as follows.
Pulse enters top right front, exits top right back,
enters bottom right front, exits bottom right back,
enters bottom left front, exits bottom left back,
enters top left front, exits top left back and just sits there open ended. lol
About finding ones signatures, would it not be harder to see a source in the city then if one was in the country. Would the city be a better mask.
giantkiller
@Wattsup,
I went back and read the 1st post of this thread and the building faster than thinking struck at me. We have all built way too fast. But at this stage the builds are more intense in their geometry and are simple to throw together. Having said that then ponder this:
In my left coil, GK135 (the name will stick), the inner most coil (6"), could use a gap in the middle. This would model after Smith's and Kunel's where that is apparent. I Believe Tesla, Dollard, and EVGray did the same thing but used a spacer to build up the center so the outer primary sat farther out in diameter. That would be a good way to hide a technology. Nobody thinks about 'Rippin and strippin'. The mind just assumes there is a continuous wind and if someone asked or I said 'continuous' then no one would think to ask. And by hiding that simple little gap one could disable any further attempts. The gap gives a weak magnetic field. And I think it is mandatory. Also on your last pic of the 2 horizontal rings the weak magnetic field if horizontally between the rings.
The Bloch wall in space is the mandatory key because it takes too much energy to manipulate the Bloch wall in a magnet.
In the attached: the blue is the suspended primary, the red is the secondary and the gray is the weak magnetic field in the gap.
Rosphere
Quote from: giantkiller on April 30, 2010, 01:17:23 PM
...The gap gives a weak magnetic field. And I think it is mandatory. Also on your last pic of the 2 horizontal rings the weak magnetic field if horizontally between the rings.
Quote from: orbs on October 10, 2008, 02:53:43 PM
...It's important that you understand that these lattice cells never touch one another, and there is a reason why they do not. It is all part of the communication within the lattice. Energy transfer within the lattice also mimics physics at the smallest levels -- also being atomic structures that do not touch. It also mimics the most elegant part of your body -- the part that is responsible for your thinking -- for your memory -- for your remembrance, and for your reactions -- the Human brain. The synapse parts (the wiring) within that organ do not touch either. These are the ways of the physics attributes that transmit (or relay) energy. It is not new. Look for it, for it's everywhere...
wattsup
@GK @GK @GK
I had prepared a post but will not post it because I re-read your last post and I just clicked on something that may be a damn good answer to producing a moving field.
The biggest problem is how to make the field move inside a coil so that an outer wound coil can actually feel that there is movement in order to get energized. We usually pulse one coil and then  hit the resonant frequency and we get something out of the other coil but not much. We use AC transformers and even they have limitations because by alternating the polarities, all you are doing is switching the poles but keeping the blotch wall in the same location.
Based on the above, I think I am realizing what SM meant by pulse and apply a small voltage. The small voltage is a starting point to pre-energize the coil then you apply your pulse to it. That is OK, but we have tried this many time without any real good results. So what are we doing wrong?????????????? Hmmmmmmmmmmm.
What if the pulse is in the wrong location. What if the pulse should not enter the coil but be used to alter the coil.
What if you take a long core or a toroidal core. You wind one coil all around the core or toroid and you snip the coil at the center most point (as you clicked it in my brainiac with your post) and lengthen those two wires. So you now have two coils. When connected back together and when you apply a DC voltage, the field is long or complete over the toroid and well defined with a north and south ends and a generous blotch wall at 180 degrees. So then, all you do is redirect the two center wires to make two smaller half coils that will now produce four polarities and two small blotch walls at 90 degrees and 270 degrees to a toroidal relation.
Since last night I have dropped everything to get this point across and have made the diagram below to better explain it then my low level talks. So if you wind a coil over the first coils, you should get some great movement at low cost. So imagine a toroid with four inner coils, quads and you do this same thing on two blotch centers or even on the four blotch centers. What would the Lenz law say about this. I don't know but I think this has to be looked at extremely seriously.
In the diagram I am showing a simple relay switching. If transformers can work at 60hz, why not this. Or whatever way if possible to do with transistors. Whatever it is, it needs to be looked at ASAP. Guys, please copy this diagram and the post on your computers in case it gets removed. lol
We never know what can be a seed for thought. This is why we are all here.
wattsup
