Understanding electricity in the TPU.
Started by wattsup, October 18, 2009, 12:28:42 PM
wattsup
@all
OK, since no one will post some concrete or pertinent questions, I will just ignore the irrelevant comments and stick to the facts. Hopefully eventually you will see the light. lol
The STPU or 4" TPU measures 4" in diameter by 2" high with a wall thickness of 1". I just tried it and you can fit perfectly 10 x 9vdc batteries in that area and have a perfect 4" by 2" by 1" toroid. Wow, what a coincidence. Now just put some proper spacers between the batteries to hold it in a circles, make your connections then add a reed contact plus a mercury switch and tape it all up. Oh, but if you do that then the battery terminals will still be noticeable from the top. So you do like SM did and use some hard glue material over the top to cover the terminals. All available at the RatShack. lol
In the STPU video the bulb was lit for approximately 70 seconds. Wow. So let's organize the grand parade because the STPU really showed us something so special and so grand.
Now if you think my trying to expose the SM TPUs as fakes is a direct attack on your personal efforts, you are wrong. When I started this thread it was to understand the electricity in the SM TPU. Blame the videos for not being good enough to withstand deeper scrutiny. You guys just don't realize that up till now, all your builds, were yours and have no relation whatsoever to SM TPUs. Get it through your heads already. You are all confusing the issue. None of this is about you or me. It is only about SM TPUs.
@otto
I did not waste one minute of all I did because there is passion and determination behind it. Just like you. Your accomplishments are yours buddy and it is not due to anything or anyone else but your own efforts. Don't confuse the issue that if you have good or any results, then the SM TPU is real. You are far to great for that kind of petty thinking that is omnipresent with some members. My bench time these days is only average 1-2 hours because of all this other SM stuff I am trying to get across. Every post I make is very difficult to do because I know it is not what you want to read. But do you want me to lie and say wow everything is so fine and dandy with SM devices.
There is much much more................ we'll go slowly.
otto
Hello all,
@sigma16
OK, no cores in the TPU!
Maybe you can explain me the 2 plates in the open TPU?? Wooden plates??
Maybe you can explain me why somebody in 1 of the videos says for the 4" TPU 1 pound and for the 6" TPU 1 1/2 or so, pounds? Wooden cores? Or maybe a lot of wires?
The same "story" like months ago!!
@wattsup
I suppose youre leaving the TPU because its a fake, as you say.
Try then the "Sweet" coils. Maybe you will find out something exciting and a big, a very big  secret.
@Lindsay
a few days ago you asked what SS device would give the same nice, sharp kicks like a tube.
Not a SS device but the B A T T E R Y!!
Have a nice day.
Otto
powerunlimited
@wattsup
glad you got of the matrix( massive deception),I have been out of it for about 2 years,so are you saying that the STPU used 10 ,9v rechargable batteries.
So that powered the 100 watt bulb for 70 seconds
sounds possible .
giantkiller
What about Bill Muller?:
From Bolt:
QuoteThere are other clues but i agree frequency can be any waveform. However the TPU is known to wind up slowly and decay slowly according to SM vids. When i get around to practical testing i shall be looking for LC tank type of oscillators where the control coil is centre tapped because i seen this ring and decay in RF. In other words the TPU is almost in resonance by its own control coils.  I believe the kick does not need to come from switching the fets hard in fact  i bet SM had a 9 volt PP3 battery tucked inside some designs are running very weak LC oscillators which slowly induce the forward circular magnetic motion around the collector coils. These gentle oscillators may not even require more than a few milli amps and they shall be sine waves because this is LC.  As the system speeds up the speed of the mag wave passing around the collector coils produce the massive pulse wave NOT the control fets. Its a means to an end. I see it as parasitic oscillations being induced on the collector to emulate a mechanical wheel. The construction of 2 LC oscillators are providing the control to the system and its very easy to pick the second harmonic of the LC and feed it one segment ahead. The 3 frequencies are very weak in themselves but collectively they create a constructive wave pushing the mag wave around the collector coil.  These spikes will happen when the right frequencies  are hit and the collector begins to accelerate. The other control coils will use the pulse which has been collector produced NOT by the fets and feed that to the gate of the next segment for timing purposes only. As the system speeds up the trigger pulses provide phase control of the oscillators in other words phase locked loop.  With the right combination the perpetual motion should be set up of course we dont know what that is yet. As SM has stated we must detune the Q of the system because when the PLL is bang on correct the circular RE racing around the collectors will cause a meltdown so the effectively  of the control PLL is detuned to harness the power. The over winding of all three coils collect this energy as the output.
Of course this is my take on the TPU and till we can reproduce it then it just the passing of ideas.
I believe its very much akin to the SSG. When we look at any conventional electrical generator the action of coil and magnets passing each other produce a sine wave AC output not a square wave or pulse. Likewise with SSG i am assuming the voltage rises and declines as the magnet passes the coil except the collapsing field produces this peculiar RE kick which is collected AFTER and as not produced by the control fets themselves so we should not be attempting to produce this kick because it will come to us later as an artifact.  They are only used for timing purpose and the diode prevents the real electron flow. With TPU i believe we are attempting to reproduce the SSG physical wheel and we should NOT be looking at producing the actual pulses. So the control to emulate an SSG wheel would be sine wave not square or pulses.
@wattsup
sounds possible .
So try it and scare away the noobs.
powerunlimited
I just hooked up 6,9v batteries in series (54vdc) and partially lit a 100 watt bulb,I need 5 more to do a better test.So far Wattsup your right, on the
STPU,Radio Shack did sell mercury tilt switches and reed switches around the time of the video's.Its possible the STPU is a fake but the others could be real ,I'm very curious as to your proof on the others being frauds.I think some are real but I'm open to listen
to your proof,I see a lot of people are getting real upset here,you have really shaken the boat.
