Magnetic Experiment Confirmed!
Started by PaulLowrance, October 24, 2009, 01:49:14 PM
powercat
Isn't this the difference between permanent magnet and electro magnetism.
cat
PaulLowrance
The magnetic field from an electro magnet does not produce DC current. Anyhow, in this experiment there's no batteries. It's just a magnet, insulated wax paper, and a metal bolt.
Paul
powercat
Ok Paul
I would have thought that any magnetic field would produce some voltage, and if you did work with this voltage the magnet would slowly lose its magnetism.
cat
onthecuttingedge2005
Quote from: powercat on October 24, 2009, 05:43:50 PM
Hi Paul
Is it not a fact that magnetic fields produce electricity
cat
Hi Cat.
I think magnetic fields(virtual photons) 'move' electric fields(electrons). magnetic fields are not electric fields, they are separate forces but interact with each other when force is applied to make them move.
hope this helps.
Jerry ;)
gyulasun
Hi Paul,
Is it possible that the current (or voltage) your meter shows comes from the enviroment and the meter probe wires serve as an antenna pick-up wires?
If you agree you could repeat the measurements with the same components, except using much shorter pieces of probe wires like just  2-3 inches?
Also repeat the measurements outside, well away from the place you have been so far.  If you find significant differences at different places, then it has been worth the efforts.
Thanks,  Gyula
