Magnetic Experiment Confirmed!
Started by PaulLowrance, October 24, 2009, 01:49:14 PM
PaulLowrance
Quote from: exnihiloest on October 26, 2009, 06:07:53 AM
Certainly not. A field does not "move". A movement means that something goes or flows from here to there.
A "moving" magnetic field is just an illusion similar to a rotating  light spot in a room: the light does not move on the walls, photons only move but radially, not in the apparent direction where the spot goes. The intensity of the light on the walls is simply changing with time giving the illusion of movement along the wall surface.
The apparent speed of the spot (or of a "moving" field) can even exceed the speed of light because no matter/energy movement is involved. This speed is fictitious. It has strictly nothing to do with v in the Lorentz equations. It is irrelevant for the description of a conductor moving in a field. The speed of the conductor moving in a field is only the speed relative to the observer. It is not a question of relative speed between the field and the conductor, this idea of field speed is outside of "conventional physics".
We're talking about conventional physics. Your above statement is not according to conventional physics.
Conventional physics adhere's to the following Einstein statement, "Only relative motion is observable; there is no absolute standard of rest."
Another interesting subject is rotating fields, which also move,
http://en.wikipedia.org/wiki/Magnetic_field#Rotating_magnetic_fields
Paul
PaulLowrance
This morning the current was 79pA.  Just 69 away.  ;D
Paul
PaulLowrance
Here's an outline, with some modifications & additions, of the past several days worth of experiments:
http://globalfreeenergy.info/2009/10/26/magnetic-experiment-updates/
Regards,
Paul
PaulLowrance
I should mention that the surface of one of the Al plates is definitely different. Perhaps it's looks different because it has a rougher surface? Perhaps it has a thicker oxidized layer? Anyhow, the recent experiment is considered a MIM diode, Metal, Insulator, Metal.
Paul
