giantkiller
An important passage...
@Gy,
Wrong response...
@Wattsup,
Watch out for the amperage!
@SM,
Thanks for the response.   8)
forest
IMHO to make a pump you have to have pure DC positive to attract electrons. AC will only tickle them. Tesla patented bifilar coil for purpose of electromagnets so it's very suitable for that.You have to have also spark gap to make that DC pulsating to allow electrons return to ambient state.
You have to have bifilar in non-inductive connection to primary, and spark gap should operate strangely without oscillations.
Don Smith method , also TPU.
giantkiller
In this pic
http://www.overunity.com/index.php?action=dlattach;topic=8227.0;attach=43527
Replace the G-box with a stungun.
Quote from: forest on April 01, 2010, 03:21:36 PM
@Wattsup,
I too have a coil similar but on an E-core not An O-core like yours. I took the little black video coils posted by Sauron and modded it to a configuration like you show. But in mine the HV is inside the low winding like a little ferrite core Tesla coil.
But what Starcruiser posted is one within another within another like a trifilar pancake. All the older tpu windings from Marco and Mannix stated '3 all the way around the ring'. And alot of old TPUs are just that but probably not connected mobiusly like Otto did the GK4 but on a copper core.
I did notice that Starcruiser's schematic had no capacitors in it.
I pulled out a number of my coils and they can all be mobiusly wound and driven like a bifilar pancake, maybe trifilar. Guess that is where Moaby gets his name.
Thought I did this before but now that I think of it the double pulse protocol does the same thing. One pulse right behind the other like a snake biting its tail. This gives an electrostatic effect. Like what is mentioned in the document.
Well I have some easy setups this weekend to do...
There are many ways to skin a cat.
In reference to the GK4  pic:
I could never figure out why and where the destructive chatter of this monster came from. Take notice of the iron runs all connecting together at the end of their runs. With 3 different frequencies this coil would randomly conduct through the iron runs in different directions and different times. When one pulse is low another would be high. This would happen in the Tera/Giga/mega hertz. That explains where the damaging energy came from. And the iron wind is 90 degrees to the others. Major stress going on here in this coil like a traffic jam version of a Rodin coil.
sparks
  Electrons moving appear to displace prevailing electric field states already existing.  They warp the gradient as they carry their monocharge scource through other electric fields.  They cause the prevailing field to change dimension.  Depending on their velocity the electric fields they pass through will alter.  Some longer wavelength electric fields will now be partitioned by the movement of the electron.  Producing two higher energy state waves from the one lower energy state wave.  The shortened electric fields or higher energy photon can work to ionize and accelerate electrons bound to neutral atoms.  Note you need the lower frequency oscillation and the electron velocity.  The faster she goes the greater probability that a lower energy wave becomes two higher energy waves and these higher energy waves are able to ionize atoms that the lower energy wave could not.  This can lead to an electron cascade event.  This is not energy from no where.  You need the low frequency wave to be altered and accelerated electrons.  Then something to observe the increased electron density induced polarization.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
giantkiller
The string is plucked, then press fret 12 to get an octave or higher harmonic. 8)
The new interconnections of Otto's pic of the GK4. Not bucking but precessive.
Quote from: sparks on April 02, 2010, 07:15:46 AM
