starcruiser
GK, have you tried a magnet to bias the mag-amp? I ask this since there is no control coil on it and you need something to saturate the core.
As for the 5khz (ish) driver, why not just create a tank and insert the mag-amp in series with it? Then perhaps parallel. The control coil would be the input for the driver frequency and the magnet is to bias the core. Just some thoughts.
Carl
giantkiller
Thanks for the combination. I will try that. I am also going to rotate the small toroid 90 degrees in connections so that the the potential goes down 1 side of the amp and the return trip is on the other, like Bedini magnetic shearing, BEMF. I will post schems later. Muwhaha!
Quote from: starcruiser on July 24, 2010, 12:54:24 PM
sparks
  A magnetic amplifier simply uses variable impedance of a transformer to control a higher power circuit.  Instead of gating a highvoltage dc supply with a low voltage dc supply you are gating a highvoltage ac supply with a low dc current flow.  Changes in the amount of dc flowing through the amp will change the impedance of the reactor without the ususal isolation problems we see in voltage driven switching.
  It is ridicuoulus for an ac supply like an alternator not to charge a capacitor as a load.   This way the electrical currents move first to charge the capacitor then reverse to discharge the capacitor back into the generator.  The load is drawn from current transformers monitoring the oscillations.  The power companies are probably doing this already bouncing power between plants and those pole pigs arent nothing but ammeters for their kvars.  Meanwhile we are led to belive that the load effects the amount of fuel consumed by the plants.  One pulse from 0=130 volts repeated a million times a second is alot more powerful than the one pulse from o=130volts pushed out by a generator for one millisecond to excite and sustain the system in oscillation mode.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
Mk1
@gk
I had time to think about your toroid spark , now things i would like to say .
So DC travels in the wire , high freq travels outside your experiment and video is great to see that .
Now we know that glass holds water and electricity in the same manner , what if you made two plates and connected them to the coil of the mag amp and put it into a glass , the glass should fill up each time ...
Anyway , this is pretty far off and don't expect any response , but had to share the idea of putting transformers into a glass  :-\ ...
Mark
giantkiller
Two opposing power pathways: http://www.youtube.com/watch?v=tzNjIViEw7g
This shows another result set of fields eclipsing and providing a boost.
Next I will add more combinations and 5khz to the magamp config. Am winding a new set of Magamps out of coils of garden wire. Real quick and dirty.
@MK1,
I had the Notched PVC coil with aluminum ring plates on top and bottom, ran 3 frequencies into it. The tingles shot off the sharp edges. Like throwing mercury on the floor. Stun guns are alot safer than RE. When ever my coils spit I tend to back off. The headaches can last for 3 days. Not good. I have used shields but then I blew up equipment. So I tread lightly.
Back to the bench...
