BESSLER WHEEL SOLVED
Started by circle, November 01, 2009, 04:54:32 PM
DO YOU THINK IVE GOT THE GOODS?
YES.. CLEAR PERCEPTION AND SOUND LOGIC AND PERFECT INSIGHT HAVE WON A BATTLE IN THE WAR AGAINST IGNORANCE
NO.. THIS GUY IS YET ANOTHER SELF DECEIVING BEFUDDLED CHARLATAN
circle
I FIRST FOUND A PICTURE OF BESSLERS WHEEL IN NOV 07
FOR FIVE DAYS I DID NOT REALLY DO MUCH OF ANYTHING ELSE OTHER THAN ATTEMPT TO UNDERSTAND IT
NOT EVEN SLEEP
MY FIRST IMPRESSIONS WERE GROSSLY INACURATE BUT I DETERMINED THIS TO BE THE CASE, AND FORMED A NEW IDEA
AGAIN AND AGAIN  TILL I WAS OFF IN THE GERMAN ARCHIVES READING 'MACHINEN TRACTAE' IN ITS ORIGINAL FORM
AT SOME POINT IT DAWNED ON ME THAT HE HAD NO INTENTION OF REVEALING THE METHOD IN HIS OWN WRITINGS
  AND SO I TURNED AT LAST TO THE DESCRIPTIONS OF THOSE WHO WITNESSED IT FOR THEMSELVES
AFTER RESOLVING ITEM AFTER ITEM I FINALLY FOUND MYSELF WITH A FULL UNDERSTANDING OF THE INTERIOR OF THE DEVICE
ITS NOT COMPLICATED BUT IT MIGHT BE A BIT BEYOND ME TO BUILD IT
IM INTRESTED IN WORKING WITH SOMEONE WHO IS ABLE TO ASSIST IN THE CONSTRUCTION
TO BE SPECIFIC.. THERE ARE ONLY TWO POINTS THAT I DO NOT HAVE AN EXACT FINAL DECRIPTION OF
AND THEY WILL HAVE TO BE RESOLVED IN THE FINAL STAGE OF BUILDING
THESE TWO POINTS BEING
1]THE EXACT POSITION OF ATTACHMENT FOR ONE END OF THE SPRING
2]THE EXACT METHOD OF ATTACHMENT OF THE OTHER END OF THE SPRING (EITHER CENTERED AND BALLANCED OR OFFCENTER AND FUNCTIONING AS FULCRUM)
IM TEMPTED TO JUST MAKE A VIDEO AND BLURT IT ALL OUT BUT THE IDEA OFF PASSING ON WHAT MIGHT BE EARNED DOSENT SIT WELL WITH ME ANY MORE THAN IT DID WITH JOHANN BESSLER HIMSELF
A FEW POINTS THAT IM SURE THOSE WHO ARE ON THE RIGHT PATH HAVE ALREADY CONSIDERED..
THE WHEEL WILL FUNCTION WITH ONLY ONE SET OF TWO WEIGHTS
BUT IT WILL MOVE QUICKLY DOWNWARD THEN VERY NEARLY STOP AS IT RETURNS BACK TO THE UPRIGHT POSITION
YOU HAVE TO BE VERY CLEVER TO CAUSE ONE WEIGHT TO LIFT THE OTHER
THINK ABOUT IT
THIS IS AS DIRECT AS I CAN BE
AND FOR SOME IT SHOULD BE A CLEAR EXPLANATION
THE DEVICE IS EFFECTIVLY A MOBIUS - JACOBS LADDER THAT IS SO VERY NEARLY PERFECTLY BALLANCED
THAT THE ENERGY STORED IN A SPRING IS ALL THAT IS NEEDED TO COMPLETE THE CIRCUT OVER AND OVER AGAIN
IN EFFECT.. ITS 'FUEL' IS THE STORED KINETIC ENERGY IN THE METAL OF THE SPRING
THE DEVICE IS NOT PERPETUAL; IT WILL ONLY RUN UNTIL THE SPRING WEARS TO THE POINT IT CAN NO LONGER 'RESET' THE DEVICE
(THE PENDULM ON THE EXTERIOR IS A GOVERNOR)
{THE NON SELF-STARTING DOUBLE THICKNESS REVERSIBLE WHEEL IS SIMPLY TWO EQUAL CONSTRUCTIONS OF 'EIGHT PAIRS OF SETS OF WEIGHTS' SET OPPOSED TO EACH OTHER}
overtaker
From Bessler's apologia Poetica:
A wheel appears - is it really a wheel, for it does not have a normal rim.
It revolves, but without other wheels inside or outside,
and without weights, wind, or springs.
Do you believe your idea will work without springs?
I would recommend Ralph Lortie if you are looking for a builder. He can be found over at Besslerwheel.com
He will keep it confidential.
Unless you have a working wheel, you may want to put a question mark after the Bessler Wheel Solved.
Good luck.
AB Hammer
circle
Welcome to the forum.
I agree with overtaker.
>>Unless you have a working wheel, you may want to put a question mark after the Bessler Wheel Solved.<<
Ralph Lortie, would be an excellent person to send it to have a evaluation. He is my mentor on helping others in this quest.
PM me and I can send you his email.
Alan
Alan
Justalabrat
Yes, but don't go into besslerwheel.com saying you have solved the wheel, they will eat you alive! :'(
Don't show the idea to noone!!!! Don't even trust your own family! They will steal it from you!!!
Go to different machine shops and make them build the parts individually. Then you can assemble it yourself and patent it ASAP! You have already made a big mistake by talking about it in public without a patent. I will repeat don't show or talk about it to anyone, they will steal it from you. Both ABHammer and Ralph will convince you to built it for you and then patent it on their names!!!! You will die poor, and your family will leave you for your foolish mistake, while they will become millionaires.
So after 5 years when you have your patent and wheel come and talk about it, for now you must disappear completely before your idea is stolen!!!
PS: Be careful on this forum. There are many hackers that can hack your computer and steal your files. It's better to not use the internet anymore untill you have a patent.
