mscoffman
A motor not under load is simply idling and the power
That it is using is wasted. If you put a resistor in series with
it is it simply idling using less power. While an unloaded
motor spinning is interesting...it is largely useless.
Whether the motor can increase it's power based in mechanical
load or not depends on it's design...real world motors can draw
additional current to support additional mechanical loads. AC
motors do this via phase shifting their current vs voltage waveforms.
Of course a generator might overload a motor depending on the
resistance of it's output load, as the generator acts as a brake.
For overunity determination purposes an idling motor is largely
meaningless...You'll need to tell that to Joe Newman.
If you want to determine overunity you need to loop your motor
back, so that it runs itself, then pull off power as it runs and
split the power into a (user) load that dissipates it. Attach a clock to
load being on, which gives the energy (milliwatt seconds) being pulled
from the motor and is being dissipated (thrown away)...compare that
to the energy density of the power source for the motor...when you
have more - that is overunity energy being produced. Forget the
instrumentation, other than the clock and the determination of the
filtered DC voltage and current dissipated by the load resistance
which at a constant voltage should be a constant.
Doing anything else is largely a waste of time.
:S:MarkSCoffman
Airstriker
I recommend reading this short post by exnihiloest, as IMHO it's mostly what's in ORBO and 2SGen:
http://www.overunity.com/index.php?topic=8597.msg231475#msg231475
If something is not right in this post please point this out.
@GB
I've finished the discussion with you.
gravityblock
Quote from: Airstriker on March 06, 2010, 05:16:33 PM
@GB
Your partner has done nothing but intentionally twist the facts, along with you and a few others.  I've already posted how the facts are being twisted, and you keep insisting otherwise.
GB
Airstriker
Quote from: gravityblock on March 06, 2010, 06:24:07 PM
GB
936 posts. nice. I wonder what percentage of this is the same kind of shit.
You know what? Fighting with the devil you eventually become one. Look in the mirror and stop saying about twisted facts when you can mix ten different theories in one post. No I will not show here any of these. I've already read enough of them.
If you still want to play your little war just go order the new Battlefield.
supersam
@airstriker
why don't you start a new thread ?  like "reasons steorn replications don't work" , or "bad steorn replication experiments measurments",  just shut the fuc* up here! PLEASE!
or show some of your experimental evidence for anything you espouse!
lol
sam
