the "elites" plan to adjust the earths orbit ! (long).
Started by nitinnun, December 20, 2009, 10:01:39 PM
nitinnun
Quote from: MileHigh on December 23, 2009, 11:30:31 PM
The Earth is going to remain in a stable orbit for billions and billions of years provided it does not get clobbered by something moon-sized smashing into it.  The orbit will be so stable that it will outlast the sun, which will eventually turn into a Red Giant and swallow up the inner planets.
You can calculate the angular momentum of the Earth in orbit around the Sun, as well as the Earth's moment of inertia about it's axis.  Both of these values are so unbelievably massive that would take astronomical amounts of energy to change either one.  Energy that is beyond our capabilities to generate for the foreseeable future.  The Earth is in orbit and spinning in a frictionless vacuum.
All talk about the Earth changing its orbit or its axis of rotation when in fact there are no unbalanced forces acting on it are complete nonsense.
your attitude is the opposite,
of an attitude that produces something.
if everyone had your attitude,
than we would go for thousands of years,
without discovering anything new.
because people would only know,
when they already assume they know.
and nothing new would dare be considered.
the suns magnetic field,
is likely the only correctional force,
that earth has.
the high voltage,
high amperage,
high frequency HAARP spiral,
CHANGES where the suns orbit-correcting magnetism,
reaches the earth.
because higher frequency magnetism,
has less resistance,
than low frequency magnetism.
and magnetism flows away from high resistance,
and towards low resistance.
if a pocket of high frequency,
low resistance magnetism,
is created over norway,
than that means the suns orbit correcting magnetism,
it attracted more towards norway,
and attracted less towards the north pole.
or towards anywhere else, period.
if a basketball is spinning on the ground,
and high frequency is applied,
to one side of the basket ball,
and ambient low frequency,
is on the other 3 sides,
than the basketball would move,
towards the higher frequency.
the basketballs orbit,
would change.
it is the same reason why overunity torroids,
produce excess electricity.
the electrons willingly move,
from an area of lower frequency,
towards and area of higher frequency.
because electrons want to move,
from higher resistance,
towards lower resistance.
millions of volts,
at who knows how many amps,
might be small,
compared to the total weight of the earth.
but even a small adjustment,
can alter the entire orbit.
and there is no limit,
to the number of times,
that this small adjustment,
can be made.
they could use HAARP thousands of times,
if they wanted.
to slowly implement the orbit of their choice.
which is why the spirals have been seen,
all over the world.
because they are carefully pinpointing,
where the adjustments are made !
just like a modern space vehicle,
needs countless thrusters,
to carefully adjust its movement,
in space.
Groundloop
@nitinnun,
The spiral in Norway was a failed 3 stage of an Russian rocket. It had nothing to do with
any HAARP installations in the world. What you are posting is ideas from inside you head
and this has nothing to do with the outside world. Use your brain to check some facts.
The spiral was observed and photographed as far apart as 1000 Km in Norway. If you put
the images onto a map and draw a line from each image in the direction that particular image
was taken, then you get lines that point to the White sea in Russia.
The sun rise is in a east direction and was right under the horizon because it is
winter time in Norway. This set a perfect stage for illuminating the exhaust gasses from the missile.
This particular missile had a gas leak in the third stage that produced asymmetrical trust, thus made
the rocket rotate. At an altitude of almost 100 Km the air pressure is almost non existent. This made the
rocket exhaust gasses disperse very quickly making the spiral formation illuminated from the sun.
There are images on the Internet that shows the contrail from the missile from the ground level and up.
(See attached image.)
Don't take me wrong, I have absolutely nothing against free thinking persons like you, but posting
all this nonsense in this free energy forum is a waste of bandwidth.
Groundloop.
sparks
  Harrp is a study of the electromagnetic phenomenon created by the collision of coronal mass ejection  aka solar wind on the day side of the Earth.  The shockwaves generated by this create longitudinal waves in the ionosphere as well as the interplanetary plasma mass.  They are called Alfen (hope I spelled this correctly) waves.  The Harrp deal is trying to generate these waves in a portion of the ionosphere to study them and verify that the aurora borealis is caused from magnetic reconnection causing space storms.  There are a huge amount of communication sattelites out there that man in his infinite capacity to be stupid is becoming reliant upon.  Trillions of dollars invested in the new communication cage or grid we are becoming reliant upon.  The Sun burps all that shit down the tubes.  We worried when the computers were expected to go down in 2000 now think about a worldwide blackout due to every transformer on Earth and in the sattelites above generating power in excess of anything man has ever done for the last 200years collectively.  Electrostatic fields spontaneously arrising all over the place.  You ask me heliophysicists know this shit is coming and soon.  Harrp is an experiment to see how bad it can get or perhaps an attempt to reinforce the magnetosphere to save the new tower of Babel we have built.  GPS gone Compasses gone. Telephone gone.  Micrwave communications gone.  AC power plant main transformers gone.  What a frigging mess.  So instead of giving out the truth and allowing the people to prepare the industrial military complex is taking care of its own collective ass and fuck the rest of the lesser people who dont belong to the club.
Think Legacy
A spark gap is cold cold cold
Space is a hot hot liquid
Spread the Love
jikwan
to nitinun
the master extrapolator
youre going to have to publicly eat your hat if those lights dont shine over new zealand
i for one will be taking note of any sightings in the area-and if there are you will become
an overnight sensation
keep on going man, some of us appreciate radicals
zen is the art of seeing everything and noticing nothing
billmehess
After reading your posts I was wondering if you and Lawrence are taking the same medication?
