Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
Mannix
There is an effect in this spiral coil ..that only manifests in another coil .
Have a look ..see it and then you will all find agreement .
Like..... WTF is this?
But no ....many of you have already decided  with out even looking ..and you HAVE instruction on how to see it.
Rosphere
Quote from: -[marco]- on January 15, 2010, 06:49:27 PM
The TPU is like fireing a gun at a small target in total darkness.
Ok see,what i did,i started to look at all devices i could find and i looked for the device that had the most info on it.
This new device became my new project.
The information is overwhelming and after looking into the details you know exactly:
*what you need
*how to build it
*what to use
*what to look for
*circuits
Etc. etc truly everything you need to do it...
Also the inventor is prepared to talk about his invention, that fact alone blews the TPU into the garbage can.
I had a hard time switching from total darkness to a new brilliantly lit workbench....Seriously i am still having problems with that,it cannot be this easy can it? it sure can...
It does not matter if anything is real or fake if you do not have enough information about it to replicate it...Because you will never suceed.
So you can either shoot in the dark forever or try to grab more light....
This inventor, "prepared to talk about his invention," would it be DLS?
ramset
I have to say
This obviously makes a lot of sence
Whats on your bench Marco??
{besides the Fat girl]
Thanks Grandma
pauldude000
Quote from: Mannix on January 15, 2010, 06:54:56 PM
I wonder if any body knows how that pulse DC is created in the secondary?
Electric field would be the first strong guess, based opon several facts.
1. The two coils are effectively magnetically uncoupled.
2. The geometry of the primary winding implies a regularly twisting rotating magnetic field. (string of pearls type visualization.)
3. The elctromagnetic field associated with the magnetic field would therefore follow suit, in a string of pearls configuration, leaving both high field potential and low field potential 'gaps' rotating around the coil with the field.
Since the magnetic field is 'out of phase' so to speak, it cannot be directly responsible for any main observed affects. A rotating electric field of similar geonmetry would force electrons to move REGARDLESS of orientation, due to repulsion of electrons trapped within the valleys in potential.
Such a field could not produce anything BUT dc spikes. The rotating magnetic string of pearls would naturally affect the local magnetic background, causing magnetic reflections and resonances of no real power or significance to appear in the secondary coil, thereby confusing the issue.
However, since I have no means to "see" or really measure a moving electric field, it becomes a guess, though a strong contender for logical reasons.
Paul Andrulis
Finding truth can be compared to panning for gold. It generally entails sifting a huge amount of material for each nugget found. Then checking each nugget found for valuable metal or fool's gold.
Rosphere
Quote from: Mannix on January 15, 2010, 07:16:27 PM
It will cost me only time to test this as I already have all I need.
Despite the drama, this is an interesting effect.  Induction is taking place, in a unique way.  How does induction occur given the relative angles of the wire between the two coils?
How exactly can we model the magnetic loop line interaction during this process?
Can these magnetic loop interactions cause some vortex event and strong interaction with 'ambient' energy?
Can a small displacement current be made to induce a large conduction current?  The world may never know.
