Agentgates´s TPU setup with strange wavehill hump
Started by agentgates, January 05, 2010, 09:28:18 AM
Mannix
Ok
It is exactly as Tony has described.
I have not progressed to the point he had ..Im just new to this effect.
I am just simply driving a mosfet with a function generator. not an expensive one. a 555 should work the same
20 ohms from ps 30 volt to top of coil
lowside switching
1khz square wave saturating the fet  on  ( if the fet is not saturated no effect)
no fet driver yet.
there is a 27 ohm current limit resistor to gate but not needed in with my fg.
very rough indeed
I am yet to hook up a propper 3 phase controller . (Jason Owens type) I will wait untill there are more people with this base effect.
80 mm post tube 50mm high 36 slots top and bottom
again not optimum
.25 wire primary (tony said .19)
1 mm secondary 5 turns
This is all here over and over, it is best to read tony's posts.
Everything so I have was as tony described  I have more to do , lots more, so Im not the best one to ask.
When as few more of us get propper confusion, Im hopeful sure tony will add something so that we can get to second grade more quickly.
Just start the thing up and wind a few turns of secondary...hey 1 if you like .
I did find it interesting that my oscilloscope was not able to see it on some ranges which is still confusing to me
and may be a sticking point for some . A better probing method will develop Im sure
I have posted pictures and there is a small dc component in the lowest  point of the pulse that should not be there. but what would I know?
I just hope that we can do this in public ...so everybody just consider this a toy of curosity for now please.
Not curious ? No worries. Nothing needs be said.
If any body else (with steam)can help better then please do
Lindsay
ramset
Thanks Lindsay
I agree
Chet
Thanks Grandma
Rosphere
Quote from: Mannix on January 15, 2010, 08:25:54 PM
@ rosphere, paul,
you wont be dissapointed
Lindsay
You've done the diligent replication.  I would like to try running primary winds inside the tube on the shortest path to the other side; parallel to the axis of the tube.  Like yours, my primary winds outside the tube would be 45 degrees from axis of the tube and the secondary would be wound on the outside of the primary-tube assembly.  This would tell us if the inner wind configuration, separated from the secondary by the tube and the outer winds, comes into play or not.
Maybe tomorrow when I'm fresh.  (Yawn.)
Or maybe marco's large primary: http://www.overunity.com/index.php?topic=8227.msg216241#msg216241
Mannix
Quote from: Rosphere on January 15, 2010, 10:11:48 PM
I strongly recommend starting from the base point ..It is just that the base point of reference is confusing enough.
Sure, do changes, lots of them, just make a little steam first.
ketone
QuoteTo many real inventors try to get "funding", and in so doing get tied up legally, all info unsharable with anyone, and the invention shelved. That is what happens when one gets greedy
Paul, you are spot on...why don't they just start selling to friends and family instead of trying to go for the GOLD in one fell swoop!
