Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Staffman
Maybe some large steel washers between the toroids and the generator coil. Just thinking that the added permeability would help, not sure how much tho. Could even use steel as the coil form instead of using ferrite.
Another thought is to use steel wire in the generator coil, but the resistance of the coil would suffer.
Bruce_TPU
Hi Alex,
In discussing this project with some others this evening via telephone, a suggestion was made to make a steel horseshoe and link the magnets to see if a clearer path for the flux, might allow for better performance on the coil generator.  This was also suggested, I think by Gyula some time ago.  It would be an easy experiment, just use some angle iron or the such.  It would be worth a try.
Cheers,
Bruce
EDIT:
Also really worth trying, if you still have several toroids on both ends, change that to only ONE toroid per end and see how that does on the output generator coil. Thanks!
Groundloop
Bruce,
Yes it is a little disappointing but this test was with the resonant oscillator
running and the phase between the two toroids was horrible. We get better
result with a switch that has frequency and duty cycle control. My toroids
are not optimal either. Remember that this is the first system thrown
together just to see if the method works.
Also, 100 Ohm load is not the best load for the output coil because I have found
that this is a high voltage system, not an transformer. The output is like an RF
transmitter and the load must fit the impedance to get the correct output.
We have proved that the system works. We have proved that it is possible to
use several coils as output. And we have proved that a magnetic field can be
shielded and modulated. We have also proved that when using resonance then
the input will be greatly reduced.
So I still think it is important to build a proper and bigger system that are much
better designed and tuned and test that. This I will do.
Alex.
Bruce_TPU
Great, Alex.  I am right there with you.  Lot's of room to experiment and to make improvement.  I think it has merit.
As you said well, we have proved many things out already.  Now to optimize!  My toroids some day will arrive (lol..I hope tomorrow) and then it is winding time.
Cheers,
Bruce
gyulasun
Quote from: Bruce_TPU on January 08, 2010, 02:01:57 PM
Hi Gyula,
Yes, you understand what I was thinking...but, as you state, we need to match the load to the tank...any ideas of your own, while I ponder?
Simply looking for a means to make the generator coil(s) as "efficient" as possible.  We want every single amp and volt!  LOL
Cheers,
Bruce
Hi Bruce,
Well, lumped circuit matching theory is at our service here, at least this is what I thought of.  It simply means you can get the highest output power if you conjugate match the generator coil to a load.
So in case of Alex gen coil, it has 1.2 Ohm DC resistance and an L self inductance with XL inductive reactance. This is best matched to say a incandescent lamp that has 1.2 Ohm resistance at a certain rated wattage AND you have to place a capacitor in series with the lamp to compensate for the gen coil's XL with an equal value of capacitive reactance,  XL=XC at the output frequency.  (In this simplest matching case, you create a series resonant circuit and you "ruin" the unloaded Q quality factor of the gen coil by "doubling" its copper resistance i.e. adding the same value resistance, 1.2 Ohm, the load, in series with it.)
Of course you can choose to use coupling coil(s) wound onto the same generator core, you can wind the gen coil with several taps to make matching variable to different loads (you may not have a correct wattage lamp with the needed ohmic value at hand etc etc). In these matching cases you place a capacitor in parallel with the gen coil to make it resonant at the output frequency and test which tap gives the best output power on a load (a lamp, a power resistor, etc) because there would be one tap only wrt any one coil ending, where you achieve the above requirement, all the other taps will give less output power.  Effectively in this parallel resonant case you have a resonant transformer, with taps or with coupling coil(s) to transform down the high value resonant voltage.
rgds, Gyula
