Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Bruce_TPU
Hello again ALL,
Well, another small break through, as I have changed core material from insulated steel wire, to uninsulate soft iron wire coated with a thin coat of oxide.  I still have plenty of more room for more laminations.   Please remember, there is a magnet at the bottom of the laminations, that is on top of the bottom toroid.
New Power Output:
V  7.26
R  43.3
I  0.16767
P  1.2173 WATTS
Center Coil Power Output:
V  .239
R  .9
I  0.26556
P  0.06347
Cheers all,
Bruce
Bruce_TPU
Hello again,
Two more discoveries, one on purpose and one by accident!
First, I added to very tiny magnets, in attraction to one another, on the sides of the core, about half way up.
Next, a "lego" piece moved, and the green toroid that you see in the foreground, was attracted to the magnet, standing on end.  Both resulted in a new output power total:
New Output Power:
V  7.65
R  43.5
I  0.17586
P  1.34531
Now, please remember these toroids are already in series, doing nothing, because I am out of Brooks coils...So, I wondered what would happen if I put my big toroid there in the place of the green one, up against my magnet... (magnet says, "UP" by the way, because if it is facing the wrong direction, forget about it...LOL)
NEW POWER OUTPUT:
V  7.9
R  43.6
I  0.18119
P  1.43138  Watts
New Power Output on Center Coil
V  .261
R  .9
I  0.29
P  0.07569
gravityblock
Naudin released Episode 8:  2SGen simulation with FEMM, towards more output power..., http://jnaudin.free.fr/2SGen/indexen.htm#simulation
GB
Bruce_TPU
Hello All,
I got to thinking about my tiny magnets on core and decided to test with out them, since only test was with them and with new toroid next to the large magnet.  Well it is better WITHOUT tiny magnets on soft iron laminate core.
New Ouput:
V  8.02
R  43.6
I  0.18394
P  1.47516  Watt's
synchro1
There's a big difference between people who try to sound smarter than they really are and cause allot of confusion and others who really know their stuff and make the subject understandable. I have no trouble following JLN's tutorials and the contributions of Nicolay Zaev, but some of the comments that find their way into this forum amount to just a bunch of egotistical baffle gouge!
