Solid State Orbo System
Started by Groundloop, January 06, 2010, 12:21:24 PM
Groundloop
@gravityblock,
Thanks.
Working on the attached right now. Cap charge up to +85 volt
when the circuit runs on 9 volt.
GL.
jaculat
Hi all
I'm playing with my CML2Sgen (when I have some time): http://www.youtube.com/watch?v=_wm5uFUaLxg
made some measurements but it's not optimal configuration so... but what is important I've notice strange behaviour, you can notice on clip that when I'm connecting led other led gets brighter (usually should act differ)... Can someone explain it?
I'm working to use PC sound card as generator/oscilloscope because now I feel like blind man (only one meter)...
Energy4All
Good Work. I am particularly pleased with the scalability by virtue of simply adding magnets or increase magnetic potentials.
Groundloop
@All,
My SCR based charge controller did not work that well. The SCR
has a tendency to stay short circuit when it was triggered
because the input charge was high enough to keep the current
going through the SCR. So I have designed a new charge
controller based on a mosfet instead. The new circuit should
work like this: The neon bulb will start to light at 65 volt plus
the zener voltage. This will give 14,1 volt to the gate on the
mosfet and the mosfet will discharge the capacitor to the
load. To get a long discharge duration, I use a high Ohm
resistor on the gate so that the mosfet will stay on long
enough. I will build this circuit soon and test it.
(Edit) I have tested the attached circuit. The input voltage needs to be approx. 100 volt
         for the circuit to work.
Groundloop.
Energy4All
I was just reading over Howard Johnsons' Spintronics The Secret World of Magnets which you will find available for download at http://www.scribd.com  The effect you are describing is covered from a permanent magnet arrangement point of view in the section on the Gate. I found it a fascinating read. Your electromagnetic approach with respect to the ORBO Tech is worthy of pursuit.
